- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
If you have the HAF, then it is possible that the campground itself has very low voltage, causing your HAF to do its thing, which will increase amp load. I have found this to be true at one spot, but never consistently. I use a lot of power, including the OASIS electric burners, washer, dryer, tvs, laptops, etc...never once have I had to worry about it and never once has the 3rd air shutdown due to the EMS.Interesting! I'll revisit this again at Sparta and or Newmar again this fall. Try to sort out the over voltage draw. There is a Hughes Autoformer between the Shore Post and panel. Claims 120V+ at the receptacle?
I suspect that maybe your coach is not balanced on the panel, which is one thing you can check by watching loads on L1 and L2, and see if they appear balanced.
Another thing that is different, as @Neal mentioned, I have always had the microair easy starts on my units. This does eliminate the hard spike that could trip a breaker under high load.
Check your balance first, as that is easy.
