Dometic Penguin II impossible to find
A few years ago when I was looking to replace my units I spoke to a Tech person at Dometic and he said that in reality Dometic does not make a 15 k unit and in fact their 15k unit is a 13.5k one with a little bigger fan. I would go with a 13.5 one and pull the fan assy from the old one in case I decided to swap the fans
Thanks Neal… we checked those. No heat pumps. We’re going to go with a Freshjet 5 A/C only. We called those places yesterday. They showed no stock or the one that did show stock apologized that they haven’t updated their website. But…No, they don’t have any.
I can understand why Newmar steered away from Dometic. They are getting stung with tariffs from China imports. Our replacement Penguin II 15k heat pump is only four years old and was $1299. This Freshjet5 15k A/C only is $2241 …
We’ll let you know how “direct” … the “Penguin II direct replacement” is.
Friend of mine got the LAST Dometic 15K heat pump for his Dutch Star, from Newmar Parts about 3 weeks ago! Or, that's what they told him!
My question, what is Newmar doing about manufacturing & building coaches??
Maybe they are installing big "roof fans" as a replacement!;)
I had read a thread explaining that Newmar is switching Brands to Coleman. Unsubstantiated...news. They cited Dometic mfg. had moved to China...and tariffs were a concern. IDK.
I'm hoping the Freshjet 5 lasts longer than the Penguin II. My rear unit - knock on wood - is still running. We got a Iittle over 5 yrs on our first front unit...and a little over 4 yrs on the second. The new heat pump version is supposed to be rolling out in the Fall. And I do not know why, but that unit will not work with our CCC2 thermostat. So, it will require: New thermostat, replace rj11 with rj45 comm cables, and for your remaining Penquin II and perhaps your Dometic board linked to the ME-AGS-N...you need an adapter board to let it communicate with the new thermostat. PIA.
I can't imagine the wire runs much less to the t-stat. Anxious to hear what you learn. Also, how the existing thermistors integrate.
I wrote the experts. Maybe the fleet specialist at Newmar can share some gouge.
I'm thinking the thermostat to the basement...then over to the AGS... half bath...up and over to the rear A/C...then plenum rated from the rear A/C to front A/C. But I'll share what they recommend...or any sketches they may have of our rj11 wiring.
United RV in Ft. Worth claims to have several Dometic 15k btu Penguin II w/heat pump ( white only) in stock. The black is out of stock . ~$2300.00. The online salesperson texted he couldn't be absolutely certain until he has eyes on it on Monday.
I believe the Heat Pump was out of stock when I had checked. The A/C only was probably available... but if going A/C only, I may as well try the newer version. And the A/C only can use a CCC2 control board. They just dropped their prices...but we are skeptical because a lot of places are selling drop shipments and Dometic is weeks behind.
Ready to move something!
Hey @Chuggs - if you haven’t tried Dyers, I suggest you do. We had a great experience with them last winter when our outdoor fridge went ‘legs up.’
Wow. That will be a lot of stuff hard to find, AC’s toilets, awnings?
Thanks so much,
I checked them out...seems they have the Series 3. The Series 5 is the "Low Profile" version and uses a more recent refrigerant... Seems like yesterday R410A was the craze... but now they are starting to comply with the EPA regulations to switch to R32 Florane.
We'll find out later this morning if we can find an actual FJX5557M thru a nearby RV dealer.
I already committed on a Freshjet 5…but I got a call from Showalter and they found out that National RV refrigeration in Shipshewana, IN has Penguin II 15k Heat a pumps left over.
If your’s is shot…call quick while they still have some.
They specialize in refrigeration units…but evidently do stock some A/C units.
I spoke to Mary, at Newmar Service. She confirmed that Newmar is installing Coleman products now. She also confirmed that last of the 15K Heat Pump Dometics are gone.
I think it was a pretty smart thing on their part. I'm in some part surprised by Dometics approach to this. Right now --- they have no Low Profile 15K units to offer. And the 15K A/C unit I purchased...has no documentation. (Other than a file I can find about the Air Distribution Box...which Newmar's do not use).
Anyway --- I used my network tester. The RJ11 wiring in our coach, I now understand. There are four runs on our 2 A/C coach. Thermostat to A/C Front. A/C Front to A/C Rear, A/C rear to AGS command Controller in basement. Which is exactly like the old installation guide for the Penguin II laid out.
I installed our Freshjet 5 yesterday... It comes with no control board. It has only the housing, the evaporator, condenser, compressor, capacitors and ptcr, the fan unit, and wiring for those items...which all go thru the box where our controller is normally housed and to a 6-pin molex. What to do? Well you have to purchase a separate controller that is like the one in the basement. It comes in a metal box with connectors all around the perimeter. One accepts the 6-pin from the rooftop unit. And you plug in the 6-pin DC/Furnace plug from the coach, the remote cabin temp, the two RJ11 comm plugs, the outdoor temp sensor, freeze sensor, and power from the Molex Power kit... And then have to figure out a good place to mount that. I have seen these installed inside the Air Distribution Box on other Rv's. We don't have that luxury. So, rewired the unit using the parts I scavenged from my Penguin II. The new unit has a metal housing on the compressor side of the unit with the two capacitors and PTCR. I would have left it there...but didn't want to cut into my Easy Start bundle to pull a wire out...in retrospect it would have saved me some time... I threw out the start capacitor and ptcr and moved the RUN capacitor over to the control box housing...where it is on the Penguin II. It's all the same wiring, save the fact there is no Reversing valve in a Non- heat pump unit.
Why am I telling you this?
Be careful buying a Freshjet 5 if your installer doesn't have experience installing it in a Newmar. He may do it fast...and find a place to put the added control box...or charge you a number of added hours to rewire it to use the original controller.
The only difference I see between the two...is the stand alone has a molex connector for a heat strip. The board we have in the Penguins is setup for a reversing valve... I haven't looked into it...but the same pins might do the heat strip function...I'm not sure about that. I'm not bothering with a heat strip anyway.
Anyway... The mounting holes are on a little mound...so water wont' pool by the lag screw head... So, I need to source slightly longer lag screws...and and I need to put some butyl tape under the foam pad where the screws go in...to insure a better seal. Not sure what the lag screws are drilled into down there...but it doesn't seem like I'm getting good purchase on anything. Except for one longer lag screw used by Land Yachts when they replaced my unit in 2020.
I'd use 3m 5200 if I thought the air conditioner would last my lifetime. But these things are not built to last.
I need to check with a magnet...but it looks like the Internet rail they place in floor is aluminum vs powder coated steel. I have an original unit on the back...and it's steel...and rusting out. So, if this is aluminum...it might actually not rust out.
Anyway...going to take a day off...and then find some new lag screws and butyl tape to secure the unit better...
Yeah, umm, nope. This is going to be an expensive trip to Newmar when one or both fail. I'll have both done at the same time, not gonna be cheap I'm sure. Ugh!
Will you be installing Soft Starts in thew Coleman(s)?
