Slide not closing all the way
Zman300
Oshkosh, WI
New Aire 3343
34'
Freightliner XCS
Cummins 360HP
None
See in the picture, one of the slides isn't closing all the way at the bottom.
What could be causing that.
Thanks
I'd try opening it all the way, check for obstructions, then close it all the way again. If still no luck you may need to reprogram the slide controller. But if it's been working fine, I'd be taking a close look for something inside the house side as well as outside for obstruction first and foremost.
Your best scenario is it just needs the travel adjusted.
Check to see the slide locks are moving freely. I had problem with one bedroom lock that was not moving well. Dutchstar Don did a great writeup on how to clear them. I will look for it
Here is "within the thread" of lubricating the slide locks.
If the actuators (at the bottom corners of the front and bedroom slides cannot be moved by hand they need to be lubricated. Mostly from the top down from outside on a ladder.
Will check for obstructions.
It's the bedroom slide not sure what motor it has.
The link takes me to another site. Is that right?
The link is the Resources area of this site. It's a little confusing, click the Download button at the top right of the page it takes you to and that will get you the PDF attached.
The slide controller is likely on the chassis rail in the bay forward of your pegboard bay.
Will read up on this.
This is all new to me.
Thanks
Pegboard bay?
Thanks
Pegboard bay?
Maybe yours doesn't have one, check the passenger side aft bays on the chassis rail for electronics. It may be a good idea to call Newmar support.
Did some reading. Still lost.
What is this. What does this do when it closes.
Looks like that may be stopping it from closing all the way.
When the slide comes in that paddle pushes the slide lock on the inside top of the slide up to secure the slide. If you look at your slides on the inside top, fore and aft, you'll see the white paddles that come up and push against the wall to secure the slide.
Controllers look like this - there are likely 2 that are same model (bedroom and Living room small slide)
They will likely have flashing red numbers that change and will be different. Model could differ -
Note: One of mine is unplugged as a scaffold is up the side of the coach in front of the bedroom slide out... So that is my "old man safety system..
I see the paddles.
Will look for the controllers.
What could cause it to get out of adjustment.
