Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Moved the slide out far enough to work the paddles.When the slide comes in that paddle pushes the slide lock on the inside top of the slide up to secure the slide. If you look at your slides on the inside top, fore and aft, you'll see the white paddles that come up and push against the wall to secure the slide.
The motor runs both ways but nothing moves.I believe your slide gearbox just gave up. Have you tightened the gearbox bolts? I think it is recommended to do it yearly. Mine got checked every six months.
Empty under the bed, remove the 4 screws holding the floor panels in place under the bed. Then you will have to crawl in there with a flashlight. You should see a shaft going to the gearbox. Check the bolts on the gearbox. But, from what you have said, you may have to replace the gearbox. Good luck and let us know what you find.
