Zman300
- Jul 7, 2025
- Oshkosh, WI
- New Aire 3343
- 34'
- Freightliner XCS
- Cummins 360HP
- None
Will check for obstructions.I'd try opening it all the way, check for obstructions, then close it all the way again. If still no luck you may need to reprogram the slide controller. But if it's been working fine, I'd be taking a close look for something inside the house side as well as outside for obstruction first and foremost.
Resource icon
slide controller programming guide
I'm new at this.Your best scenario is it just needs the travel adjusted.
Will read up on this.Here is "within the thread" of lubricating the slide locks.
If the actuators (at the bottom corners of the front and bedroom slides cannot be moved by hand they need to be lubricated. Mostly from the top down from outside on a ladder.
Often Missed Slide Lock Maintenance - iRV2 Forums
On the last few trips, I noticed my bedroom slide was not operating smoothly. When I would bring the slide in, the front edge would seal against the coach and then the rear edge would follow, tweakingwww.irv2.com
ThanksThe link is the Resources area of this site. It's a little confusing, click the Download button at the top right of the page it takes you to and that will get you the PDF attached.
The slide controller is likely on the chassis rail in the bay forward of your pegboard bay.
Maybe yours doesn't have one, check the passenger side aft bays on the chassis rail for electronics. It may be a good idea to call Newmar support.Thanks
Pegboard bay?
Moved the slide out far enough to work the paddles.When the slide comes in that paddle pushes the slide lock on the inside top of the slide up to secure the slide. If you look at your slides on the inside top, fore and aft, you'll see the white paddles that come up and push against the wall to secure the slide.
