Spartan chassis owners, be aware.
From Newmar.
I'm not sure what has changed at the border, I've only heard this happen a few times in over twenty years hear at Newmar, and you're my second email today with this question.
Newmar Corporation is only required to provide the sticker behind the driver's seat which is generally always accepted when crossing the border. However, Spartan Chassis does stamp the last five digits of the VIN four times on the frame rails. Once on the main chassis frame rail behind the steering axle tires, passenger and drivers side, and the same behind the drive axle tires. If you need further assistance in locating them, you can reach Spartan at 800-543-4277, for better assistance.
Waiting on a response from Spartan
If you didn't watch the video, the issue is that Spartan failed to stamp the chassis or rivet a nameplate with the full VIN number to the chassis which apparently is required by law on motorhomes built after 2010 I believe the date was. This is from the video, I have no idea what the law requires and what the problem is.
I saw this on FB earlier today ... now I know what it must be about.
I checked my spartan and no VIN. It does have a few digits from the end of the vin but that doesn’t meet the federal code.
I figured out that Amazon sells vin tags engraved and with rivets, for less than $20.
I ordered mine. Problem solved
I don't know about that @redbaron, that seems to defeat the original intention of the tag. I'd be a tad bit skeptical. . .
Did the thread on the FB Newmar Owner's Group about this get deleted?
Anything on YT is clickbait BS
So I challenge a Spartan owner to find the regulation and post the reference for the VIN requirement.
Best way to squash internet rumors is finding the actual info.
This is from my post "over there"
This is going to be long. I made some very clear statements, but in doing so in such a short way, it allows for gaps.
The pertinent question(s):
Pursuant to 49 CFR Part 565 (Vehicle Identification Number Requirements) and 49 CFR Part 567 (Certification):
1. Does Spartan have to stamp the VIN on the chassis frame?
2. Does Newmar as a final stage builder have ti verify the VIN has been stamped on the chassis frame?
3. What are the penalties if no VIN was stamped or affixed to the chassis frame?
ANSWERS:
Yes.
• 49 CFR § 565.13(e) requires that the VIN appear “clearly and indelibly upon a part of the vehicle … that is not designed to be removed except for repair, or upon a separate plate or label that is permanently affixed to such a part.”
• In practice, for an incomplete vehicle chassis (like those built by Spartan or Freightliner Custom Chassis), the industry standard and NHTSA expectation is that the VIN is stamped or embossed on the chassis frame rail.
• This is considered the primary, non-removable VIN marking that law enforcement and DMVs use to establish the legal identity of the vehicle.
So, Spartan as the incomplete vehicle manufacturer is responsible for stamping the VIN on the chassis rail (or another non-removable structural part) and also placing the certification label with the VIN per Part 567.
2. Does Newmar, as a final-stage builder, have to verify the VIN has been stamped on the chassis frame?
Yes, indirectly.
• Under 49 CFR Part 567 (Certification of Vehicles), the final-stage manufacturer (Newmar in your example) must ensure that the completed vehicle still conforms to all applicable Federal requirements, including the VIN rules in Part 565.
• Newmar does not have to physically stamp or restamp the VIN (that’s Spartan’s job).
• But Newmar is responsible for verifying that the VIN on the chassis and the VIN on the certification label are present and consistent. If they complete and certify a vehicle without a valid VIN, they would also be in violation.
Think of it this way: Spartan creates the VIN, stamps it, and applies its incomplete-vehicle label. Newmar must carry that VIN forward and ensure the finished coach has a compliant certification label tied to the same VIN.
Severe.
• Under 49 U.S.C. § 30165, NHTSA can assess civil penalties for each violation of the VIN and certification requirements.
• As of 2023, the penalty is up to $26,315 per violation, per vehicle, capped at over $130 million per related series of violations.
• Beyond civil fines, a missing or fraudulent VIN can trigger:
• Vehicle recall obligations (manufacturer has to fix or repurchase the affected vehicles).
• Seizure of vehicles by law enforcement (since they cannot be legally registered without a valid VIN).
• Criminal exposure if the omission was intentional or tied to fraud (18 U.S.C. § 511 prohibits VIN tampering or removal).
In summary:
• Spartan must stamp the VIN on the chassis frame and affix its certification label.
• Newmar must verify and carry that VIN forward when certifying the final-stage vehicle.
• Failure to stamp or affix a VIN risks NHTSA civil penalties, recalls, registration problems, and possible criminal issues if intent to misrepresent is proven.
PENALTIES:
Exact Statutory Language — 49 U.S.C. § 30165
The law states:
• A person who violates any regulation under various sections of Title 49 — including VIN requirements — is liable for a civil penalty of up to $21,000 for each violation, with each vehicle counted separately. The maximum total for a related series of violations is $105,000,000.
• These amounts have been updated: as of the 2025 reviser’s update, the maximum per violation is now $27,874, and the cap for a related series is $139,356,994.
Implementation in 49 CFR Part 578 Current Dollar Values:
• For violations of the relevant Safety Act sections (including VIN requirements), the civil penalty is capped at $27,874 per violation, with a maximum of $139,356,994 for related series.
• If false or misleading reports are submitted, there’s a daily penalty of up to $6,823, with a series cap of $1,364,624.
Newmar and those that are publishing the false / misleading information regarding the vin can face the same stiff penalites.
Yep, I see the legal threats and censorship in action as the video is down too. I see Casey is now on irv2 as NewmarPres.
