flyboy013
- Jul 24, 2020
- Mountain Aire 4531
- Spartan K3
- Cummins ISX12 (500HP)
- 2023 Jeep GC Summit Reserve
- Yes
I figured it was about time to replace my electrical outlets from USB-A to USB-C. Any recommendation on which brand/model I should be looking at? I assume newer Newmar coaches have USB-C? If so, anyone know what they are using?
Nor sure how you utilize these devices…. Where do you hook them up?In an RV I have found it more useful to use 12 volt DC based USB-C converters. Several different models available. That way your USB devices can be used without an inverter/shore power.
And these deliver 5 amps instead of 3 amps typical for USB conversion from AC.
Anywhere you have a 12 volt wire. Or pull 12 volt to where you want it. Much better to power devices in storage since you don't need the inverter active.Nor sure how you utilize these devices…. Where do you hook them up?
I'm tired of using bricks to charge my newer devices that have USB-C connectors. My coach is nearly 8 years old and I'd like to keep it "fresh". I would like to have a bedside charger for my iPad that doesn't require a brick. I'd like to have an outlet with a QuickCharge capability. As @redbaron stated, Newmar uses a press on style outlet which doesn't leave much room for a more modern outlet especially if it has a QuickCharge capability.
I suppose I could add a DC based charging capability as @turbopilot suggests. It just means adding more holes in the bedside cabinet to install this additional capability. Is it too much to ask for a modern output in a RV? Do the newer coaches have USB-C? With QuickCharge?
That’s a good idea, and would work on Newmar as well. Not all floorplans have the outlet in the frame, but the nightstand should have more room too.First let me state I am not a Newmar owner so the same may not apply. I was able to convert my bed frame mounted 120 volt RV outlets to standard 120 volt outlets with usb charging. It did take some time and I lost a little bit of space as I had to add 2 single gang electrical boxes in order to use the 120 volt resi style outlets.
