12 volt fridge
rosenkol
It use to be that it was best not to operate the propane fridges when parked for an extended period on a hill. Is this still the case with the newer 12 volt only fridges?
Yes it cost me my fridge a few years ago. In retrospect it was a good thing as I was able to convert to a resi fridge double the size in the same location. I did have to cut down the drawers under the fridge ge but that was all. Top photo old fridge bottom is the new fridge.
I think you referring to 12 volt compressor units. We have one in our new TT and no it does not have the same restrictions as the older absorption units do. It is a compressor like a residential unit but runs 12 volts opposed 120 volts.
No! The 12v only fridge is a compressor fridge using completely different technology.
How well do the 12v refrigerators work when boon-docking?? How much solar wattage is required or at least ok for boondocking with a 12v fridge. I am looking at an Alliance Valor with a 12v only fridge and am concerned about having enough battery power to continuously run the fridge. This particular rv comes with 2 400w solar panels(800w total). Any opinions or advice would be greatly appreciated.
