Construction on the RV Barn finally starts
MarkMaxPayne
Lyons, OR
New Aire 3543
36'
Cummins L9 Diesel
Fiat 500 Turbo
This morning at 6:15am my neighbors must have loved me as the first concrete truck rolled up and the guys started the pour of the foundation and slab. Was able to find a place off my drive where I didn't have to cut any of the trees down to make room.
20260115_070836.jpg20260115_071543.jpg20260115_071521.jpg20260115_081102.jpg20260115_081102.jpg20260115_083751.jpg
Mark what are your dimensions? I'm sure those guys wanted to get that mud laid down so it would have as much time to set as possible before nightfall. Any freeze warnings in your area for tonight?
They sprayed some chemicals on it for water / freeze protection and to supposedly help with the cure time. Luckily, the low tonight is only supposed to hit 41 and no rain projected for next 7 days.
Dimensions? Just 40' x 19', but it'll be just big enough for my littler New Aire.
The current shop couldn't be expanded nor have the roof / garage door raised (property lines, how it was constructed, etc.) so I had to find a new location for this new barn. Way smaller than I wanted, but it was the only size that would both fit my rig and make it such that I didn't have to cut down some pretty awesome trees. I still have a 3 bay shop across the drive for storing any bulky items.
I justified it in my head with I'm in my "forever rig" and now at my "forever" home before I sell off everything and eventually go the assisted living route some day. Until then, party on. :) If the next owners of the property want it expanded in the back for a longer rig they can harvest a couple of mature trees and easily push the back out at least another 20'-30' if they so desire.
I guessed it at 18'. 19' is one foot better. That barn is big enough you can open a get around the coach if you need to. Well done.
open up and get around
Just curious any rebar in that concrete?
HH
HH
Yes and no. Yes in the foundation footings around the entire perimeter, but not in the 6" slab itself. I guess we will find out how that turns out for me down the road.
As long as you have a real good deep base that was compacted in layers it won’t move
Lumber delivered today so framing can start this week. Wheels that go sideways? Very cool.
Framing started today. 16' high side walls...
HI Mark: Are you going to insulate it? If so what do you plan to use? Looking good.
HH
HH
Thanks! At this point I don't plan on insulating it given my location and fairly moderate year round temperatures. The August average high is only 83 and in December, the coldest month in winter here, the average lows are only about 35. The temps very rarely go above 96 or dip to 25. This winter I think we've had only one freeze warning thus far.
My main weather issue is pine needles, twigs, and branches falling down from the tall pine trees. I plan on winterizing the rig as I usually do in the winter and then flush and sanitize the fresh water tank and lines come spring. I also plan to run a dehumidifier inside the rig all year. I have a commercial dehumidifier inside my metal shop.
If I do decide to insulate it later, I'd probably go with spray foam as it's 2x6 framing and I'm not looking for a finished interior. Because I do woodworking the metal shop will probably get first dibs on insulation and spray foam would be the easiest thing to do there. Might as well just do them at the same time if I decide to pull the trigger on the shop.
Best,
-Mark
They finished framing the three main sides. Will begin sheeting it tomorrow.
Since you didn't have any rebar, wire mesh, or fiber strands added to the concrete, I highly recommend waiting a minimum of 30 days before any weight is put on the slab. The longer it cures, the stronger it will be. It will crack; the unknown is how badly.
