Question Need advice from someone with knowledge on either 30A or 15A power systems
  • Thread starter Thread starter CIK7
  • Start date Start date
  • Featured
CIK7
I am doing a custom recreational (legally 'utility') conversion on a 1998 Volvo V70 wagon. Here is my dedicated thread for that. I just need to know what all I need for the power system and how to make it work.
Whether I build a basic 15/20A charging system or an upgraded 30A (PREFERRED) type, I need input on what all I need to make it happen. I plan to have 2 large special batteries (no battery format, chemical type, or numericals here for sake of teasers). I want to use an AC to DC converter. I thought if I used a 55A version like this then I should be able to successfully either hook up a 30A or 15/20A receptacle.
So yeah, fill me in. Let me know what all I need to look at.
The provided charger is only a 20amp charger. You can connect to 50,30, or 20 amp but will only use 20.
What other electric devices using AC power will you have on your conversion? That will determine the need.
Okay so with that charger I will only have a 20A input current. How would I go about having 30A input? I haven't looked at '30A 120v to 12v' converters, so that's next on the research list.
I will have 1 2-outlet inverter to supply 2 AC plugs for up to 500w. I MIGHT also add a single outlet 1500-2000w inverter for a rooftop A/C (ASA AC135/AC150). MIGHT.
In that case I would get a single unit 30amp inverter charger. This along with a proper breaker box for the same rating will allow you a confined space solution.
This is common in any Rv.
Can you please provide a pic of one or link to one?
Edit: is this what you mean? A power center? How would I get a 30A receptacle hooked up?
Yes those are the power centers that I was thinking of.
They have a place to hard wire a shore cord to it. Most run a short cable to a receptacle and then carry a 30-50ft shore cord with various adapters. This way you can power from 50amp to 15amp
Thank you so much! I have added a few WFCOs to watchlist so I can pick one up next month. What I read in reviews is that WFCO and Aterra make much better stuff than powermax.
What kind of circuit breaker do I need? I took a couple screenshots. Are the GE the type I need?
Edit: After watching a video and looking on Amazon instead of eBay for name brands, I noticed that it depends on the device. So I guess I need to figure out how many poles the listed air conditioner would need.
The panel should have the breakers
Get a book on basic electrical circuits and read it. You knowledge is lacking so much it's hard to answer you question. No offense intended
You might consider an inverter for the 15/20 amp outlets and maybe refrigerator and running the large consumption appliances, microwave, water htr, elect. htr., a/c, from ac. If you're planning on a lot of off grid you'd need a lot of battery to keep those bigger appliances operating.
I have found the WF-8930/50 ac/dc power distro by WFCO. Their site shows power centers and distros are separate but they look the same. Do you think that unit is alright? I plan to pair it with the WFCO WF-9865.
This looks like a great pairing.
