Problem Ceiling lights flicker when supposedly off
MarkMaxPayne
Beaverton, OR
New Aire 3543
36'
Fiat 500 Turbo
My 2023 Newmar New Aire has a multiplex LED lighting system that is controlled by SilverLeaf. My overhead ceiling lights in the living room will have a dim ghost flicker when turned off if there are other lights in the rig that are turned on. They will be off for a minute or two, then pulse on with a very dim glow for about half a second, then turn back off again. Rinse/Repeat. Rather annoying while trying to watch TV with the overhead lights off.
UPDATE: SilverLeaf says this would be an issue in the KIB module Newmar installs as they simply provide commands to it.
Anybody else have this issue? Fixes that seemed to have worked?
Thanks,
-Mark
Mine does also, cycling the salesman switch clears it for a few days, mines so faint, you need to be looking to notice
Thanks,
-Mark
The key word is multiplexed. And yes it's likely the KIB and the low power requirement of LEDs.
LED lights take very little energy. Static electricity.. Any radio techs. Resistor on circuit to bleed ghost energy when tirned off?
Yes, that is my plan B this summer: a 10K Ohm 1/4 watt resister across the LED light leads if the KIB firmware upgrade the techs applied a couple of weeks ago doesn't pan out.
I'm going to stick My neck out on this.
I don't see this issue as a mechanical one. I see it as a process error.
Can you do something about it? I don't think so unless you can address the program flow, think flow chart.
All is not well in whoville as I risked letting dealer attempt a firmware update. After spending over a year and a half sorting out the wrong floor plan being loaded into my SilverLeaf I am almost back to square one again. I should have simply went with the 10K ohm resistor.
My new issues after the dealer touched it include:
Control panel in bathroom no longer does anything other than light up.
RH and LH reading lamps over theater chairs in living room will not turn on at all.
Bedroom wall sconce lights will not turn on at all.
Bedroom accent lights turn off and on with Bedroom ceiling lights vs. via their own dedicated accent light control, which does nothing.
I have picked up a no name 3rd fan on a unit with only 2 vent fans.
Block heater plug is on when turned off and off when turned on. ?!?
Ugh, when will I learn?
Best,
-Mark
Upon further inspection, I think they might have not been done working on the lights. I found the KIB cover on the floor of the closet (not screwed in) and one of the KIB boxes open and not closed. I suspect they started work, got interrupted, and....
I was helping a friend that was having problems like that , lights flicker or not come on, blinds go down sometime, not back up. I tightened all the wires on batteries and inverter, solved his problems.
So I had the supposed firmware update applied to my KIB units by the service department while having other work done on my coach. After service my 5th KIB in the back bedroom closet was bricked (the communication bus LED stays on and doesn't flicker). This means my reading lights over the theater seats and the sconces on the bedroom wall slide don't work at all now. Oh, and my block heater outlet is now "on" when off and "off" when on almost like the NC and NO relay contacts are reversed. Of course the claim was this was a coincidence (yeah, right...) and they eventually ordered a replacement KIB. Ugh... I'm a pretty technical computer guy. How do mere mortals deal with these electronics issues?
What I'm most frustrated by is KIB dealer services techs. It took forever for KIB to respond to the service techs and even the Newmar royalty from the mothership that was visiting the dealership for our Newmar Academy class. I watched them call KIB 3-5 times a day, each time being told they'd call them right back, just to have somebody only play brail with them by texting back and forth vs. actually talking on the phone. At least SilverLeaf customer service was very responsive and helpful. I get why Newmar wanted to go with KIB vs. SilverLeaf (saves 2 out of 3 wires going to every control pad), but...
Best,
-Mark
Headed in for service again for this. So what is the over/under for my 3rd dealer service visit for my interior lights working correctly again after this visit? First visit was a KIB firmware upgrade that bricked my 5th KIB controller. 2nd trip was a lot of head scratching and KIB not returning their and Newmar's calls. This 3rd visit is them throwing a replacement KIB module at it with some prayers tossed in for good measure.
Options are:
1) It's fixed!
2) It's fixed but they broke <list>.
3) No joy, still broke, go fish.
4) No joy, but <list> is now also broken as well.
Best,
-Mark
