Problem Ceiling lights flicker when supposedly off
MarkMaxPayne
Beaverton, OR
New Aire 3543
36'
Fiat 500 Turbo
My 2023 Newmar New Aire has a multiplex LED lighting system that is controlled by SilverLeaf. My overhead ceiling lights in the living room will have a dim ghost flicker when turned off if there are other lights in the rig that are turned on. They will be off for a minute or two, then pulse on with a very dim glow for about half a second, then turn back off again. Rinse/Repeat. Rather annoying while trying to watch TV with the overhead lights off.
UPDATE: SilverLeaf says this would be an issue in the KIB module Newmar installs as they simply provide commands to it.
Anybody else have this issue? Fixes that seemed to have worked?
Thanks,
-Mark
Mine does also, cycling the salesman switch clears it for a few days, mines so faint, you need to be looking to notice
Thanks,
-Mark
The key word is multiplexed. And yes it's likely the KIB and the low power requirement of LEDs.
LED lights take very little energy. Static electricity.. Any radio techs. Resistor on circuit to bleed ghost energy when tirned off?
Yes, that is my plan B this summer: a 10K Ohm 1/4 watt resister across the LED light leads if the KIB firmware upgrade the techs applied a couple of weeks ago doesn't pan out.
I'm going to stick My neck out on this.
I don't see this issue as a mechanical one. I see it as a process error.
Can you do something about it? I don't think so unless you can address the program flow, think flow chart.
