Suggestion Water pump.
Frank1960
When using my water pump the front toilet on my Newmar 3709 Ventana fills up slowly with water. This doesn’t happen while hooked up to the water hose, only when using the water pump. Already replaced the toilet switch. Only happens in the front bathroom not the rear. Anyone have or had this problem?
That's really odd. You don't have any other pressure issues at any other areas or faucets? Does the pressure appear lower when using the pump at your faucets?
Assuming both toilets are macerator?
It’s really odd, the pressure is low at all the faucets but I think that’s because the toilet is running. Both toilets are macerators.
Are the faucets low pressure without anything else running?
My non macerator toilet is slow to fill on the pump also. New pump, new toilet. I don't worry about it. No issues in the other sinks and showers etc.
