Now, I am losing propane.....
jwwradio
Westlake, Louisiana
Sunlite
MJ13
13'
Single Axle
2008 Toyota Tacoma
My Sunlite MJ13 has a Propane Water Heater and Furnace. I have two burners on countertop but never use it. I know this wierd, but I don't use the shower because I find it too small. So the only reason I turn on the switch to heat water is to wash dishes. I am staying in it for work 4 nights per week. We had a cold night (Monday), and I went to warm the inside, yesterday morning with the furnace and Gas Bottle was empty. I went and swapped it out the put the refill bottle in place and turn on the gas yesterday evening. This am, 1/2 of the propane is gone and overnight I didn't use the furnace nor the water heater. I don't smell and propane inside the camper. This started suddenly yesterday or the day before. One other thing, I always close the valve at the bottle in the am when I leave to go to work or when I go home for the weekend. In other words, when I am not there, I turn both the gas and water off at the respective valves. I had a hose bust one because water pressure was way to high.
Could something have failed with either the furnace or water heater to cause gas to leak out.....?
Jeff W Waldrop
Your propane is going somewhere. First the dumb question. Do you see any changes in the propane level when it has been shut off. If you can't smell propane inside, start at the bottle and spray a soapy water solution on the lines with special attention to any connections. Good luck.
Yeah, I plan to stop by Dollar General am pick up a small spray bottle...
Also, pay close attention to where your lines go through a bulkhead or wall
With a previous RV we had I experienced the same issue...phantom loss of propane. Occasionally (but very rarely) when the wind was completely calm I could get a whiff of propane when I was near the front of the fifth wheel.
Turned out to be a leaky regulator. I replaced the retulator and hoses to the propane bottles (see image) and that solved the problem.
IN addition to that, the crappy hoses and connectors from the bottle to the regulator are known to leak wehn new even. I have thrown many of them away, brand new.
Similar situation with our 120 gallon tank at our Park model. Turned out to be a failed regulator.
I had to replace the regulator on our 29 year old TT last week. Took the tanks to be filled and the next day I got a whiff of propane when I walked around the front by the tanks. I was leaking from the little switch to change tanks.
I'm glad it didn't wait until we were at our very remote fishing spot.
How do you know half the propane was gone, weight? Did you weight the tank before hooking up? Also what size of tank is it? Is it a tank swap deal or refill?
From you explanation it happened over night and you didn't use the propane but had the valve open correct?
I would question the fill or initial propane lvl if you never had issues before.
Lots of soap/water poured on the fittings will show if you have any leaks there.
Another thing that is in my mind. The propane companies put in a smell that is NOT covert, it's designed to attract attention. Losing a half tank of it should be able to be smelled by the best propane detectors, commonly known as your nose.
I hate to say this, but you may need the services of a certified LPG technician. They have the tools to do this.
Just sayin'
Some people cannot smell the odor and other mistake it for something else. I went to a 5th wheel that was leaking so bad we could smell it when we got out of the truck.....20 ft away. The owner had no idea.
2 women were killed in Maine last year when they lite matches to try and clear a "garlic" smell in their new camper.
I have gone to a camper that was so bad I don't know how they didn't die that night. The burner was left on low on the stove. I told them on the phone to get out and don't touch anything like a light switch. It was a new camper also and the detector was not working.....
There is no perfect answer.
Lighting a match to clear a garlic smell? Sounds like BS
