Replacing bed gas strut
ARD
Moderator
Fulltiming
London Aire 4551
Yukon Denali
One of my gas struts came off the ball and when I put it back on the bed could not be lowered, so I assumed it seized and purchased another one. Installed new one and the bed won't come down. Are they meant to be replaced in pairs? Any advice would be appreciated. Thanks.
I have a hunch it's not bad. I sometimes lift the bed too hard and pull it out of the wood and on this trip I had one I pulled off the ball. I just put it back on the ball and it works fine. I think if you just verify it's installed correctly and gently push down see what happens. I would think they are very reliable.
Edit: Be careful but you could try pulling one off the ball at a time to see if it's one shock that's bad. Just don't let the bed come down on you unexpectedly.
Also make sure there is nothing below the strut as it comes down. It needs to have clearance to collapse down its path. I've had stuff get in the way before and that will stop it.
I installed correctly and nothing blocking; however, I paid more attention to the side of the strut that came off the ball and I noticed the forward metal plate seems to be curving off of the wood and that ball might be a little crooked. Could that cause it not to lower? I don't suppose bashing it down with my mallet would be a good idea, huh?
If you lift the bed too hard/far you will rip the mounts out of the plywood. Yeah, done that, twice I think. You really can't install them wrong. Not sure what's going on with yours.
No mallets!
No, bashing with a mallet isn't going to help. Probably the opposite. That seems pretty strange. Usually when these fail, they quit holding their load - not holding additional load. I would triple check that there is not something blocking the bed from lowering, the hinge isn't failing, etc.
I really want to bash it. So I'm guessing this is the issue and will need to replace plate. Also guessing this is why the top part of strut popped the ball. I wonder what caused it to twist. Photo below:
While that is a little mangled and should be replaced, I would be really surprised if it was keeping the bed from going down. I can see it possibly being the reason the socket end pops off. on our bed, once you start pushing down, you have to hold it to keep from really slamming. You haven't put stronger struts than the OEM's have you? Not sure WTH you could have done to accomplish that.
Yes, I usually have to hold it as I lower it so it won't slam as well. I verified that the new strut (355 N with about 80 pounds of force) is the same as the old one, but I am beginning to think my old one was fine and it popped the ball because of what's going on with the front. Oh well, I'll be at Newmar in a few weeks so no sense in buying a new plate right now. Thanks @Neal and @osuallen for the help.
