Tow backup
jagpot
California
King Aire
Cummins
Jeep Wr Sahara
I know this sounds like a funny question but what is the reason that you can’t back up with a tow? If a tranny is unengaged, shouldn’t you be able to? Asking for a friend. Lol.
Damage to the tow bar
The front wheels will whip around. If your rig is dead straight, you may be able to back a few feet. I did that once in the truck fuel lanes to be able to move to a different lane. I backed about ten feet and I took it reallllllllll slow.
Like others have said, it puts weird pressures on the tow bars…. And you could probably do it really slow and carefully, but not for very long.
I can't speak to a tow bar but with a dolly you can backup only until the trailer starts to deviate from perfectly straight behind the coach, by that time you should have already started your correction. The problem is the coach cannot react quick enough based on the length of it's wheel base.
The steering geometry on the towed vehicle is engineered for forward motion. When you let go of your steering wheel after making a turn, the forward motion resets the wheels to center (the Caster effect). Reverse causes the wheels to try to do the same but they will lock in a turned state because they cannot do a 180 degree turn making it very difficult to keep the towed going straight. Tow bars are not engineered to handle this force.
For a visual interpretation take a look at a typical shopping cart - the front wheels always pivot around so they lean toward the direction you're pushing the cart. That's the "caster" setting built in to the wheel. Cars have the same caster setting so that the front wheels want to return to center after a turn.
