jagpot
- Nov 17, 2020
- California
- King Aire
- Spartan
- Cummins
- Jeep Wr Sahara
The steering geometry on the towed vehicle is engineered for forward motion. When you let go of your steering wheel after making a turn, the forward motion resets the wheels to center (the Caster effect). Reverse causes the wheels to try to do the same but they will lock in a turned state because they cannot do a 180 degree turn making it very difficult to keep the towed going straight. Tow bars are not engineered to handle this force.I know this sounds like a funny question but what is the reason that you can’t back up with a tow? If a tranny is unengaged, shouldn’t you be able to? Asking for a friend. Lol.
For a visual interpretation take a look at a typical shopping cart - the front wheels always pivot around so they lean toward the direction you're pushing the cart. That's the "caster" setting built in to the wheel. Cars have the same caster setting so that the front wheels want to return to center after a turn.The steering geometry on the towed vehicle is engineered for forward motion. When you let go of your steering wheel after making a turn, the forward motion resets the wheels to center (the Caster effect). Reverse causes the wheels to try to do the same but they will lock in a turned state because they cannot do a 180 degree turn making it very difficult to keep the towed going straight. Tow bars are not engineered to handle this force.
Unless it’s a Walmart cart.For a visual interpretation take a look at a typical shopping cart - the front wheels always pivot around so they lean toward the direction you're pushing the cart. That's the "caster" setting built in to the wheel. Cars have the same caster setting so that the front wheels want to return to center after a turn.
