T’sOVR&Explore
- Aug 16, 2026
- Central Florida
- Former HR Alumalite P30 MH+Toad owner, now travel trailering
- Intech 2019 Flyer Explore TH, Intech 2026 OVR Navigate
- 14' Flyer, 27' OVR
- 2024 Ram Tradesman Crew Diesel, Utility Body
- Cummins 6.7L I6 TurboDiesel
Forces imposed on a telescoping tow bar from the front wheels prying against the triangle geometry get to be many multiples of the hardest braking inrush you could ever create by braking the towing vehicle.
A good friend backed up a few feet on pavement and jammed his Blue Ox bar so badly that to stop risking making it worse by going forward from the extreme bind, I chose to jack his front wheels off the ground and we pushed the front of the truck back over while my shop trolley jack was oriented sideways under the front crossmember to let it all move sideways while the front was up, no longer with front tires planted on pavement.
It is the prying force of the towed vehicle's nose heading off track in reverse caster that you need to understand.
Huge. Prying. Force.
Huge....
Huge....
