jagpot
- Nov 17, 2020
- California
- King Aire
- Spartan
- Cummins
- Jeep Wr Sahara
The steering geometry on the towed vehicle is engineered for forward motion. When you let go of your steering wheel after making a turn, the forward motion resets the wheels to center (the Caster effect). Reverse causes the wheels to try to do the same but they will lock in a turned state because they cannot do a 180 degree turn making it very difficult to keep the towed going straight. Tow bars are not engineered to handle this force.I know this sounds like a funny question but what is the reason that you can’t back up with a tow? If a tranny is unengaged, shouldn’t you be able to? Asking for a friend. Lol.
For a visual interpretation take a look at a typical shopping cart - the front wheels always pivot around so they lean toward the direction you're pushing the cart. That's the "caster" setting built in to the wheel. Cars have the same caster setting so that the front wheels want to return to center after a turn.The steering geometry on the towed vehicle is engineered for forward motion. When you let go of your steering wheel after making a turn, the forward motion resets the wheels to center (the Caster effect). Reverse causes the wheels to try to do the same but they will lock in a turned state because they cannot do a 180 degree turn making it very difficult to keep the towed going straight. Tow bars are not engineered to handle this force.
Unless it’s a Walmart cart.For a visual interpretation take a look at a typical shopping cart - the front wheels always pivot around so they lean toward the direction you're pushing the cart. That's the "caster" setting built in to the wheel. Cars have the same caster setting so that the front wheels want to return to center after a turn.
Exactly, Tow bars are engineered to be able to hook up easily. They slide and then lock when fully extended. That lock is easily released by pushing a lever thus the ease of use that folks look for. That lock is not engineered to withstand the force of "pushing" the towed.When we had our first one setup the installer related a story about someone that didn’t believe the “don’t back up” warning.
Well, they tried and broke both struts on the toad.
So towbar not made for backing up and the vehicle has different stresses when pushing backward while hooked up as well.
Well, according to Blue Ox, tow bars are not engineered to absorb severe compressions. Should you happen to have to slam on your brakes, and if your towed brakes are not adjusted correctly to assist the braking, then your tow bar can become severely damaged. They engineered for a forward pull not a reverse push.I agree the pressure of stopping should be no different to the tow bar then backing.
Wonder if you could back a little farther if someone was in the toad keeping the wheels straight?
