To vent or not?
Rd1
̶N̶e̶w̶m̶a̶r̶
̶L̶A̶D̶P̶
̶F̶L̶
with all talk about the convection, is there any benefit to vent a new install?
I don't use the microwave for heating, or very little. I do use the convection for cooking, both at home and the rv from time to time. Is it worth considering an outside vent?
any down side having a vent with another opening to the outside?
thx neal for the link to the adventium. had one in the last one 10 yrs ago from Lowes for about $1,100+. it worked well. and this one for $1,300+ not too bad
Having ordered my coach with an outside vent I will say I will never have another coach thats not vented. World of difference. The heat goes outside
Just from our experience…
We had the convection microwave in our Superstar. I priced getting a vent added then decided I didn’t really need another hole in the coach 😊
We were full time for four years and used the convection for baking bread etc.
Never really missed having it vent outside. We did have a ceiling vent in the same area that we used when needed.
Absolutely, I installed one myself but you talk about a pucker factor when I was cutting a 4" hole in the slide wall.
We've had a convection/microwave in our last three RVs and never had them vented. We have really never noticed it heating things up inside...maybe we just weren't paying attention. We're about to head out on a five-week trip and will be cooking a lot with the convection oven. I'll try to pay closer attention.
I can tell you beyond any doubt, cooking with the gas stovetop certainly DOES heat things up for us, so we avoid that as much as possible.
And also in our past three or four RVs, we have NEVER used the actual oven for anything but storage.
Sounds almost intuitive doesn't it?
Here's My take.
Venting in My view is moisture control. If your area has a fight with mold or just high humidity then venting where you cook or shower is a good idea. Mentioning the heat seems prudent, but if you camp in cooler locations you may be thinking keeping the heat is a good idea.
I don't vent! I spend My time in the desert Southwest. Then I don't like cracking lips and skin that seems like it belongs to a snake. AC removes moisture! I only use it when comfort seems prudent.
May seem like off topic somewhat, but nessisary.
If you have done any cooking in an unvented oven, in a hot climate, it is impossible to have not heated up the coach. The heat has to go somewhere and if its not going outside.......
In my previous rvs I knew it was an issue and mostly grilled outdoors in warm climates. With the current rv, its a world of difference. You do not feel any heat whatsoever
Thank you for all the replies.. seems outside climate has relevance. Having been to the SW and the NE area, it does seem to make a difference.
Question, does the venting only work for the convection, or does it also work for the cooktop as well?
I used the cooktop often in the last unit and summer time, the AC was working hard, but in the cold weather, it did help heat inside.
It works for both on mine. The micro/conv/air fryer and the stove vent
