Power steps
Larry Woodward
Newmar Dutch Star the power steps went in halfway and locked. After a few minutes unlocked and opened door they came out but when closing door locked up half way again
Kwikee steps are a treat! I carry a spare motor and controller. Replaced a motor once already, new spare under the bed. It sounds to me you probably have a bad controller but you need to crawl under and check the ground connection and all wires are secure first.
And check for binding? Maybe lube the swivel points?
Had the same problem on our 2017 DS after awhile, good cleaning and lube cured. DW is keen on keeping steps clean so they look nice and we don’t track things inside. I have lubed steps every couple months now, using a dry silicone spray
Ordered motor and replaced, works fine now. Easy install, three bolts.
Did you buy your spare motor and controller from Lippert or via Amazon? I should probably have spares on hand.
