Larry Woodward
- Jun 9, 2020
Ordered motor and replaced, works fine now. Easy install, three bolts.Kwikee steps are a treat! I carry a spare motor and controller. Replaced a motor once already, new spare under the bed. It sounds to me you probably have a bad controller but you need to crawl under and check the ground connection and all wires are secure first.
Did you buy your spare motor and controller from Lippert or via Amazon? I should probably have spares on hand.Kwikee steps are a treat! I carry a spare motor and controller. Replaced a motor once already, new spare under the bed. It sounds to me you probably have a bad controller but you need to crawl under and check the ground connection and all wires are secure first.
Amazon for about $90Did you buy your spare motor and controller from Lippert or via Amazon? I should probably have spares on hand.
