Resolved Passenger Seat Died
@Neal True If there is a short replacing the circuit breaker won't fix that. I would expect the new circuit breaker to mimic the old. You could insert a 25A fuse where the circuit breaker is. If there is a short the fuse will blow right away. If it's an intermittent issue then the fuse won't tell you anything about that. In my case I think keeping the seat adjustment functions depressed when at the stop was blowing the fuse, for example holding the foot rest button down after the footrest had fully retracted.
The cover indicates 25A.
@flyboy013 Yes the cover for the seat circuit breakers indicates 25A. My observation was regarding the cover for Breaker-1 vs the device that is installed.
Can we get a little more information on this aspect? Is this non-standard fuse easily available at auto parts stores, or is it a Newmar Parts item? And, is it something to add to the spares box?
I just needed a mini 25 amp and that took care of the problem. Picked up a mini fuse assortment at Advanced Auto Parts. And I'm wondering if the fuse blew because we may have forgotten to turn off the seat warmer in addition to the chair being turned in ways it has never experienced before. ?
Glad it's working, you should be fine. I was going to suggest moving the driver's seat fuse over to the passenger seat to test it if needed.
OK...the prong spacing on the breaker is the same as a mini fuse. So, apparently, you can easily replace the breaker with the mini fuse. Good to know. I think I will also pick up a replacement breaker or two for the spares box; just in case.
Thanks for the follow-up, @ARD.
That's what Bill did! ?
Interesting that the cover indicates that breaker-1 is 30A but the device that's installed is 25A.
I was wondering about that. When I put the new fuse in I noticed that there were 30 amp mini spares in the door, but no 25 amp.
Want to clear things up, @ARD calls for a mini 25a fuse. My 2020 is similar to @flyboy013 and calls for 25a CB/fuse. So there is a difference between between models or years.
Ok, these fuses/CBs are part of the chassis configuration, not a Newmar add-on. I have a K3 chassis and @ARD has a K2, thus the difference. @NWIP - do you also have a Spartan K2 chassis (just newer than Renee’s)?
@NWIP are you still coming to Palm Creek? I promise not to give out the new number you just texted me.
forrest gump GIF
Yes K2 but newer than @ARD.
@Neal not until March so please don’t give out my number
Thanks for the clarification on the K2-K3 chassis and year differences. We're on a 2018 K3 like @flyboy013, so will pick up a spare circuit breaker or two for the spares box.
Good troubleshooting discussion.
Probably don’t need spare circuit breaker. First off, given that it’s a circuit breaker it will automatically reset. And if it were to blow, you could always use a fuse in the short term.
