jagpot
- Nov 17, 2020
- California
- King Aire
- Spartan
- Cummins
- Jeep Wr Sahara
3. Engine offDo you turn the engine off before transmission in park or after? Or does it matter? You have been so helpful and I really appreciate it.
Thanks again and I will keep your trick in mind.3. Engine off
4. Transmission in park
Probably doesn’t matter
We pull a 2012 Jeep Wrangler Unlimited with a manual transmission(I love the old time manuals and hard to find) and we also have the air force one air brake system with Blue Ox tow bar components.What is the proper sequence for towing a jeep wrangler (Sahara) in terms of preparing the transmission? Just got the Air Force one installed yesterday and this is our very first tow.
Thanks for the info. Our Air Force One doesn't have a indicator light that I know of. The company that installed it and went over everything with us never mentioned that. I will check though.We pull a 2012 Jeep Wrangler Unlimited with a manual transmission(I love the old time manuals and hard to find) and we also have the air force one air brake system with Blue Ox tow bar components.
After hooking up the tow vehicle which is very simple with the Air Force One(tow arms, air hose, chains, break away cable and electrical plug) place transfer case in neutral and confirm it is indeed in neutral trying to gently move forward or backward, make sure emergency brake disengaged, in neutral for manual transmission, engine off and key removed and off you go watching to see brake light indicator for Air Force One behind the mirror in the tow vehicle. A far better system than the inertia brake systems.
The brake actuator air piston should have a reed switch mounted to it. This activates a small LED light strip. Instructions recommend mounting the LED strip to the back of your rear view mirror. Might download a set of instructions an give it a read. Maybe DEMCO dropped this feature. It was part of the kit when SMI was selling kits.Thanks for the info. Our Air Force One doesn't have a indicator light that I know of. The company that installed it and went over everything with us never mentioned that. I will check though.
Thanks Chuggs. I checked and it is there. Did not know this at all. I will check it out when we take the coach out. I love this site. You learn so much from people like you.The brake actuator air piston should have a reed switch mounted to it. This activates a small LED light strip. Instructions recommend mounting the LED strip to the back of your rear view mirror. Might download a set of instructions an give it a read. Maybe DEMCO dropped this feature. It was part of the kit when SMI was selling kits.
Anyway...it allows you to confirm brake activation from the helm by looking at the toad thru the backup camera system.View attachment 4468
