Using the Black Tank Flush Valve
MapNerd
RVF 1K Club
Prince William, VA
Ventana 4326
2020 Ford F-150
Time to give the sewage tank a rinse. I haven’t done this yet, and sensors aren’t fouled or anything but I figured I should probably do it one a month at least. Anyway, before hooking up wanted to know if I need to add a Backflow preventer or if anyone knows if one is already built in. I can’t tell from looking behind the panel if there is one or not.
Planned to just hook up to my hose spigot Y, then to the black tank flush valve, open the gates and let it flow. Am I doing this right?
There's already a backflow preventer in the tank rinse system. It is required by code. If you want to add a second backflow preventer at the spigot, it won't hurt anything, but it is unnecessary.
Your suggested procedure is fine. We alternately close and reopen the black tank gate valve when flushing to get a full rinse of the tank bottom. If you do this, be sure not to leave the gate valve closed for more than a minute or two. You don't want to walk away and forget you have water going into the black tank with the gate valve closed. Bad things will happen if the black tank gets filled and there's water still going in.
I flush mine a couple of times like TJ suggested above...Not more than 1 to 2 min max (set the timer on your watch or phone) with the valve closed and when I see clear water coming out, I am done.
I have a SeeLevel tank monitor at the wet bay so I can see the tank levels so I will first leave black open and run the rinse. Then I'll close the black valve and let black fill maybe up to 50% then open black and let the higher flow clean out again. Once complete then do grey. Flush black as often as you have time to do it, i.e. each black tank dump if you can. I started out doing it less frequently but this is one of those things where I don't want negligence to catch up with me. I also frequently use and vary between Dish soap in the black tank, Happy Camper extreme cleaner (put some in, fill with water, drive to next CG then dump), Cascade and of course the routine happy camper odor preventer but honestly doubt it's effective. Nothing is going to handle that much odor!! I've even done the ice cube tray dump prior to travels. I have to give all the myths a try :) I think dish soap and cascade are important to do regularly to both tanks.
Thanks all. I added a check valve to the rinse hose anyway as I found one I had lying around. I’ll probably get more rigorous about rinsing it as well.
@Neal how are you adding all that stuff to your tank, just down the toilet?
I also have a check valve at the rinse connection but as I had to replace the ones under the half bath sink I learned they have the check valve inline. Theirs is quite cheap just plastic stuff. I installed brass ones. I was chasing an odor problem.
Half bath toilet is where I add the cleaners. Mine is gravity drop but that shouldn’t matter. I also try to add water to the tank prior to the dump such as flush multiple times do it’s not just body stuff but higher water proportions.
Don’t forget to treat the gray tank, too. I also use the liquid Cascade down the kitchen sink, and shower. Soap scum, hair, and food particles/grease (even wiping dishes & pots into the garbage first), will begin to cause false readings on the gray as well. I back flush mine every time I dump if I’m at a full hook up park.
So, how are folks "rinsing" or "back-flushing" gray water tanks. To my knowledge, the provided tank rinse connection in the wet bay only works in the black tank. Have I missed something?
We do put some dish soap into both the gray- and black-water tanks when we head down the road, and dump them at our next destination.
Ok, I’m not sure on the Newmars, as I don’t have mine yet. On my current coach, I back flush via one of these.
The black and gray lines come together in a wye just before exit...I close the gray valve, and back flush the black tank with this gadget. I time the water going into the tank, so it’s about 3/4 full, cut off the water, and dump the tank. Repeat if the water‘s not running clear. Then do the opposite with the gray tank...close the black valve, back flush a couple of times. Harder to see when the gray tank’s clean.
There is no gray tank rinse nor do I think it's needed. I do have concern about soaps returning to solids and as we know soap is very hard to break down which is why I think the dish soap and cascade is important to add which I do through the sinks. I will sometimes put happy camper in the sink too, after using the barker tank for two months I can tell you the "gray matter" stinks too!
Each time I empty my black tank I let the internal rinse run with the gate valve open for a minute or so. Then I close the gate valve for 2 minutes, open/empty, and repeat. After these two fills and flushes I generally see clear water coming out.
With my gray I make sure I have 5 to 10 gallons of water in it on travel days. I add one or two pods of Oxy-Kem. It is amazing how much "stuff" will come out of the gray tank and how discolored the water will be when I empty it. During times when we are stationary I will close the gray every couple of weeks and add Oxy-Kem, let it sit for at least 12 hours and then empty.
We have found that odors can come from a gray tank just as fast as a black tank if not kept clean.
I flush my black every time I dump. I did the boiler valve mod on the outside shower valves, it's super easy to do. Then put brass quick connects on the boiler valves and the black flush connection. I keep a 3' hose to use to flush, just long enough to hang down below the wet bay door to remind me to shut it off when done because the door won't close with the hose hanging down below the opening a little. I like to use hot water, but it probably doesn't matter.
This is ABSOLUTELY the key to black rinse in my opinion. When you can make the process convenient then you'll do it. I keep a flexible hose connected to the "spigot" type connections (aka boiler valves) which give better water pressure and I use a quick disconnect that remains connected to the black rinse fitting. This has been the answer to my laziness and therefore I black rinse nearly every black tank empty now.
I need to get busy and do this too. Haven't found exactly the right valve set yet. I'd like a mixing valve setup with hose connection rather than two separate valves. What did you use @Hawkeye?
Here is what I used. One has a slightly different angle (blue) but here are options. I do not use a mixing setup as of yet, haven't had a need.
