Question Anyone using 10 meter Ham Radio in RV?
@JoeHogan, I'm afraid the Stryker may have too much wind load for the Firestick mount. The antenna mounting issue is what has kept me from moving forward with putting a radio in our coach.
I'm thinking of having a local fabricator build me a mount that can bolt to something secure (frame rail. etc.) and snake its way to the outside of the coach. Then, I would use something like this.
https://www.amazon.com/dp/B003H3ZJ76/?tag=rvf01-20
I just need to get up the ambition to do it.
Amazon.com: Hustler / New-Tronics Antenna Corp. Stainless Steel CB Antenna Ball Mount SSM-2: Electronics
So the ball mount would attach to the bottom of the coach and then the antenna would then be a few inches from the side of the coach?
The ball mount can attach to any flat surface, vertical or horizontal. And, the ball itself can be positioned so that it also adjusts horizontally or vertically.
Years ago, I used one of those ball mounts on a travel trailer, mounting it on the exterior sidewall and bringing the coax in through the wall to a SO239 female coax connector mounted on the interior wall. With a 60" mast and 60' of wire connected to the top of the mast, it was a stellar performer on all bands. No tuner was required on 6M and 80M; an internal tuner in the radio (Kenwood TS-690SAT at the time) matched up the other bands.
I'm just not ready to bore several holes in the side of our coach (or, to face the wrath of LadyDi for doing so) to mount the ball directly on the coach wall. It takes three 1/4" bolt holes and a 1.25" (IIRC) hole in the center of the bolt pattern. That's why I'm thinking about having some sort of solid bracket made to bolt to the frame and snake outside so I can attach the ball mount to it. That would also make it easily removable when it comes to time to trade in or sell the coach.
TJ,
I have considered the same ball mount as you. I am equally at a loss as to where is a secure mounting position. The front cap is convenient but flimsy. Newmar has already secured the front cap joinery at last years visit. Also, I probably do not want to listen to the wind noise of an antenna near the front windows.
Thanks for sharing.
Joe
@JoeHogan, I am looking for a location at the rear of the coach; probably near one of the corners. Need to be careful not to block either the engine hatch cover or the taillights. I think it can be done, but haven't yet gotten serious enough to look hard at the possible locations. "One of these days!"
I have several radios available for use in the coach, including a Taesy FT-857, Icom IC-706 Mk IIG and an Elecraft K2 (15W but I could build the module to increase it to 100W). We'll see where this all goes.
Thinking about options for antennas, what about a tuned loop antenna inside of the front cap. The CanyonStar has plenty of room and hopefully airflow would keep temps reasonable. A simple loop of Coax around the grill might work if there is not too much RF interference.
Find a reputable CB shop that does installs on the big trucks. I had mine done in Pa. Excellent job using two Firestiks and running the coax under the rig for a V type configuration. One Firestik straight up and one down as a counter poise on the rear ladder.
maybe as a ham you have antenna theory. You may consider a fractal antenna. Or a wire from back or front to a pole. It would look like your clothes line. if you had one.
Where is your radio mounted? You appear pleased with your setup. Do you use the radio during travel?
I had considered the rear ladder but was concerned with signal losses with the long run of Coax to the CB radio, 4 watts or less, mounted on the front dash. Also, my interest in CB is forward Biased. What are the truckers ahead of me talking about?
Not much of a CB talker but like to know what road conditions are ahead. A 11m scanner probably would work in a pinch for my purpose.
Ideally i'd put an antenna or pair, with center mounted coils near the mirrors or close to that location. A 24" antenna with a center coil could be mounted relatively high and still be below the self imposed 13' 5" limit or lower. I'd like to keep them away from stay foliage.
Not sure the mirror housing will tolerate the wind load of an antenna mount, and using the cap, ideal, would need to get reinforcement before I'd be comfortable mounting antennas to the cap. Way too easy to crack that cap and damn expensive to fix.
The orientation should be vertical. Horizontal would not be effective for this application. Gone are the days of a metal roofs, too bad. Would make a great ground plane. :)
@JoeHogan, just use a decent quality RG-8X (.240 diameter) and the loss @ 27 MHz is insignificant; less than 2 dB in 100'. That's less than 1 dB to run from the front of the coach to the back; <50'.
The radio is mounted on the wall to the left of the driver under the levelling control panel I attached it to a piece of wood that is velcroed to the wall. I hate drilling holes, but I may have to have Newmar drill a few holes in the frame so I can screw the wood on to the wall. The velcro continually pulls away even though attached in 8-10.\places.
In this setup, the long coax run under the coach is part of the V antenna system. The top of the antenna i at 13' 2".
I hope I never have to change the coax becuase the technician did such a professional intall that you cannot find the total length of the wireloom containing the coax. It is woven in with all of the stock wires, and enters the coach through an existing grommet. The power wire goes out to the engine compartment behind the dash radio and attaches directly to the house battery bank (fused, of course).
As I continue my search for radio options for the RV. I am becoming convinced that for traveling options a CB, 11m, makes more sense than 10M or even 2M. While out west you might find more activity on 2M, 10M with truckers, and the conversation might be more civilized on Ham Bands, CB is the more popular choice here in the East. Much less fiddling with a CB as well. Monitor a few channels to get the road news.
There are some CB options for No Ground Plane for RVs (NGP)... a NGP side mount FireStik Firefly kit has been developed for just this purpose.
A 3' Firestik Firefly model could be installed on the A pillar without much drama. The wire would be concealed behind the molding and dropped either below the dash or fed directly to a dash mounted radio.
The benefit of the FireFly Firestik is that is has a smaller cross section, less wind drag (easier on the mount), less wind noise, more flexible to accomodate the errant tree branch. Downside is that it is less efficient than the larger Firestik FS.
Or another option as AdbRahim has installed, an antenna on the rear ladder and run Coax up under the RV to the front. The real benefit for that work is a more efficient antenna design with a tuned counterpoise wire acting as a ground plane.
Too many choices....
