Kevin D Pem
RVF 1K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
WHAT! I'm still lurking, whats up with that?Now...for those who like to cut the batteries with a Cole-He, I’d suggest you consider something first. Some items, such as the trans, ECM, Dash, and radio, need to see a 24/7 source of 12v power in order to maintain their memory. For a trans, this would mean dumping the “driving pattern” that’s developed over time. Is that worth it? For me, and others, no.
Sorry @CaptainGizmo I have to react to this statement. Even a $2.00 Arduino board has flash memory now days. There are routines in their e prom memory that allow for clearing the flash but without the routine being activated with code sequence the memory is typically good for 10 years or more. This memory is not a chip on the board but rather built into most all single chip computers. The data books on these chips will confirm these statements.
That being said it would be a disservice to not chime in here. It takes much more and a deliberate effort to clear the settings talked about in this quote. Disconnecting the battery is not an option to clear the computer.
Those that disconnect the house battery are not disconnecting the chassis battery, in most cases, because they want to start the engine regularly for proper maintenance. My guess is that if I had a $500,000 rig I would hire someone to start the thing for a while every month if I had no way to do it. That said if you are not concerned about monthly starting you could just let it sit for extended times while visiting let's say the EU. Of course that would depend on your ability to get there.
My 24v system never turns off. This is my inverter system. My inverter keeps the fridge going, and the 12v system topped off. The inverters used in the Newmar RV is the same system used in an Off Grid house that has solar, there are other equal systems as well. As I believe @Neal stated it is actually better for electronics to stay on according to government studies that produced a trouble shooting book in the 90's? 80's. I had such a book and it gave failure rates for different components. Unmaintained (charged capacitors) were on the top of that list for failure. What that implies is that a system that is never turned off will likely outlive one that the owner is trying to save by turning it off.
