Jabber Jaw
- Nov 9, 2019
- St. Augustine Fl
- Canyon Star 3710
- Ford F-53, 26,000GVWR
- Ford V-10
- 2017 Gmc Terrain & 2017 Chevrolet Colorado ZR-2
Ok guys/gals.....with all the ingenuity, talent, & experience in this group; here's a problem that I need help solving, or being solved!
Background: I previously owned an '04 Mountain Aire; which had the extended arm mirrors which most everyone has on their coach. They are easy to view, with just a glance to either side, without really taking ones eyes completely off the road.
Problem: I just took delivery of a 2020 Canyon Star 3710. The mirrors on this coach are fixed mounts to each side. Being so mounted, requires one to have to rotate ones' head left or right to actually view the mirror; thus taking ones eyes off the road momentarily. This became apparent to me immediately during the test drive. It was a bit unnerving, but as I drove it, became more used to it, though I still don't care for it. To me, this is a SAFETY ISSUE!
So, I am looking for a way to correct this situation.
Research: First, Ramco does have a mirror kit for Dutch Star, which will work, plug n play, electrically, but there is a difference in the mounting brackets. Got schematics from them on both, and there is a different dimension of the bolt mounting holes. Even though the outside measurement of both brackets are identical.
Second, Newmar Engineering does not want to undertake any research because they have never had such an inquiry.
Third, I believe, but have not confirmed that there is a reinforcement of some type on the interior of the wall to accommodate the load distribution on the sidewall.
Solution: Need your help...ideas...suggestions!
Thanks
Thanks
