Dumping Fresh Water
msobie
Dutch Star 4018
2018 Jeep Wrangler
Can you dump fresh water from the tank without using water pump? I want to dump water but it seems it doesn’t work when I’m hooked up to city water
Yes.
Usually, in the wet bay there is a 1/4 turn valve low in the compartment and sometimes camouflaged below a bunch of other tubing. There are usually 3 low point drains. 2 are typically on the wet bay white wall. These are the plumbing hot and cold low point drains. The fresh tank valve is referenced above. Sometimes there is a label, but it’s not really much help.
Yes, there is a low point drain. Look toward the rear of the compartment tray. A decal should be afixed in proximity to the drain valve. With a flashlight, you should be able to see the valve back behind the tray. It has a connection to the Freshwater tank, and goes thru the floorboard.
It amazes me that Newmar doesn't mark the FW low-point drain valve better. On both our 2014 Ventana LE and the current 2018 Mountain Aire, the valve has been buried way back under the wet bay panel. The decal/sticker is simply placed on the wet bay panel in the general area where the valve is located. My valve is located at floor level under the forward side of the wet bay face panel.
Use of a flashlight is a good technique for finding it. Once you do find it. It is easy to dump the FW tank. I have put some yellow electrical tape on the valve handle to make it easier to spot. And, it is always farther back under the wet bay front panel than I remembered from the last time I used it. :rolleyes:
To get as much out of the FW tank as you can, tilt the coach toward the drivers side a little using your leveling system.
It amazes me that Newmar doesn't mark the FW low-point drain valve better. And, it is always farther back under the wet bay front panel than I remembered from the last time I used it. :rolleyes:
Truth!
Good tip, thank you
They do a good job of hiding it don't they.
On my DS it's in the lower left rear corner of the wet bay, through the wall. It's just a ball valve, we drain every time we get home.
Yes, they hide the valve very well.
In the factory I once worked, there were hundreds of thousands of valves. Many were hidden and/or out of reach. Similar to the fresh water tank empty valve. In many situations, in the case of a ball valve and it’s 90 degree operating handle, we would drill a hole in the end of the handle and make a reach rod from a round rod. Usually about 3/8” diameter. Sometimes we’d just bend the end of the rod as a handle to push/pull to operate the valve. Sometimes we went fancy and threaded the rod end and put on a threaded ball to grab onto.
There’s no reason that this could not be done on the hard-to-reach fresh tank valve. I’ve not done it, since I can now blindly reach in there and feel around to operate the valve. If it was a task to do daily, weekly or even monthly, yeah I’d probably make the reach rod. Until then, the deep blind reach is my process.
@msobie, have you found it?
I think it follows the K.I.S.S. principle. I only touch it once per year under normal circumstances.
