Front brake caliper broken bolt (Freightliner XCR)
J&JD
Fremont, California
Dutch Star 4018
40’
Cummins ISL450
Jeep Wrangler Sahara
Pulled the coach into the backyard after a 6 week trip yesterday and found a bolt head on the ground.
Wonder if Freightliner will warranty this problem?
At least it didn’t happen on the road! I would hope they would. Shearing a caliper bolt to me means something is majorly wrong somewhere. That just shouldn’t happen.
Actually, the bolt head was discovered just before backing into the yard which means it was there when we left 3000 miles ago. What it looks like to me is that the bolt was over torqued or was perhaps was defective. The other 5 in the caliper seem fine. I’m going to go to Freightliner in Sacramento and see what they say. I need to have the coach serviced regardless.
Yikes! Glad it didn’t result in any issues. Good engineering that the remaining bolts could handle the additional stresses
I would check for a recall by FL.. Daimler Trucks North America is recalling certain 2018 Freightliner, Western Star and Freightliner Custom Chassis vehicles for an issue with improperly torqued brake caliper mounting bolts. I couldn't find the recall # but found this information.
Sounds like it's a spare then?
Brakes? We ain’t got no brakes! We don’t need no brakes. We don’t got no stinkin’ brakes! :rolleyes:
With apologies to “Gold Hat” in “The Treasure of the Sierra Madre.”
May be a service tech attempted to comply with the Recall in my previous post or a TSB and put an impact on the bolts to tighten them. Being relatively soft 12.9 metric this one was stretched a bit thin...:-)
A quick follow up to our broken caliper bolt:
Just spent the day at Freightliner Sacramento Rv Service Center. Had our 48 month service performed (WITH AN APPOINTMENT). So nice to have a competent Freightliner dealer give appointments so you don’t have to leave the coach. Unfortunately, they were not able to replace the caliper bolt because, are you ready, the bolt was back ordered! Seems the whole front assembly is brought in from Germany so Freightliner does not stock the bolts…..go figure. The service manager could not source the bolt because of warranty issues. Good news is that the 5 remaining bolts are good and tight and the feeling is that all should be fine until a bolt is found.
