Drinking Water - coach or bottled.
B&T RVers
Vero Beach, FL
40"
2018 Jeep Wrangler Sahara
We are about to head out for the summer and we are having discussions around drinking water. We have a 2021 Ventana - so there is the coach filter + the filter in the frig. I feel that should make the water safe. My wife thinks we should be drinking bottled water - which is a lot of plastic.
what do you all do?
Thanks.
I sanitize with bleach at the beginning of the season. Then I drink heartily from the coach, city and fresh water tank.
From the coach. Four years FT and never had a problem.
It's going to come down to personal preference. I'll cut to the chase, I am fine with tap water at restaurants, I drink from the frig water dispenser. I have a two filter system for the house filter which I changed out from Newmar system as some have done.
Thanks Neal. Was it a big effort to switch out the single filter for a double?
Have installed a dual filter in the DS, carbon block & particulate. Had the same in previous coach. We have traveled to every state, drunk the tap water in ever one…..20 years and no ill effect so far. Bottled water is very overrated IMHO.
Not, not a big effort, but yes, there is some planning and effort involved as you may have to route the water lines in a wider path. It's fun like all mods and worth it. Always improving.
Water from the frig, try desperately to stay away from plastic bottles.
We santitize at the beginning of the season and drink from the coach city and fresh water tank....same as we did for years in our 5'vers.
Safe travels.
I've seen rust colored water come from a tap at a RV Park.
We spent years lugging bottled water into the house and the MH but several months ago bought a Berkey water filter and it is wonderful.
Here is a link: Techno RV/ Berkey
P.S. I have no affiliation with Techno RV.
The first thing I do prior to connecting my water line is purge the pump. Run it for a few seconds and get the yuck out as it may have not been used in a while. This also prevents this yuck from blasting your filter and causing it to crap out early. Always purge the spigot prior to connecting is my advice.
And purging the spigot you also fill your hose prior to connection to the RV and don't have the air purging inside at the fixtures.
All the water is likely safe. However Change in mineral content, my system does not like. Seems I am not alone the dogs stools are runny when we move if we don't giver her RO water.
Enough of that topic. We use Ozone to purify the water. We then filter with carbon block filter. We then run drinking water thru RO system. Seems like a lot but we know that poisons they don't test for and salts vary with location. The ozone is really set up so any water supply can be used like a stream or lake.
Have a spigot filter and a plumbed filter. Brush teeth, make ice cubes, and generally use house water with no issues. However, I bring bottled water to drink because my wife doesn't trust the MH water. Plus, it helps conserve if we boondock. We just side trip it (not full timers) so it's really not an issue for us.
