Anyone used Flexseal around vents and skylites on their travel trailer.
mhbell
Utah
Forest River Cherokee
Arctic Wolf 271RK
30 ft
2013 Chevy Silerado 2500HD B&W Turnover Ball, Andedrson Ultimate Hitch
Like the title says Has anyone in the forum used Flexseal spray or liquid around their vents and skylite on their travel trailer? I don't want here say or my friend did this or that. I want to hear from actual users. What were the results? Did it hold up?
Mel
Mel
I used the spray on a previous motor home. Lasted about a year and then failed. Can't speak to the stuff in the can that you brush on.
after a year what happened? Did it leak, peel, or flake?
Mel
Probably best to stick with the products made for the application. Use a combination of Eternabond tape and/or Dicor sealant.
As osuallen stated, I just think lap sealant and self leveling sealant is purposed for a reason. That said and not hearsay, I did use the tub of flex seal around the outside barrier of my steel shop I had built to stop that itty bit of water that seeps under the metal frame around the floor perimeter during a heavy rainstorm. It works okay.
After reading the label I use something else.
