- Nov 2, 2019
- Fulltiming
- London Aire 4551
- Yukon Denali
- Yes
So it's been a fun few days (cough). As I was driving up a mountain pass, my check engine light and alarm went off. With nowhere to pull over, I stopped in the slow lane and called Spartan. I had 3 DEF faults and found out later I had a 4th, an engine torque derate fault. As I was 30 miles from the campground, I was advised by Spartan to continue on and call him once I arrived. He told me I needed to find a Cummins authorized person to come out and clear the codes and do a forced regen. He said my DEF faults indicated that the sensors detected some abnormality. He also said that they have very few spare parts and they are reserved for people stuck on the side of the road. FYI, new DEF parts will be available in August, as they are waiting for chips from China.
Jake from Jake's Diesel came out to help me. If you are ever in Pagosa Springs, he is the one to get help from. He helped me two years ago with a slide motor. Reasonably priced and smart as a whip. In any case, he reviewed the faults and my connections and felt certain that a forced regen would take care of it. I followed him to a parking lot that trucks utilize and there we did the forced regen. It indeed worked.
I share this experience for a couple of reasons. There is a post on the other forum by the Newmar Man about disconnecting the speedometer as a temporary/emergency fix to make your destination and not have to be towed. In the thread someone mentioned they tried it and it did not work. I asked Jake about it and he advised against it as he felt it would further compound the problem. As I continued to read about Cummins fault codes, I read about the OTR Diagnostics Tool which can be used to clear codes and do a forced regen. That sounds like a much more reasonable emergency tool to have on hand. Later in the thread, a couple of people also mentioned this tool and carry one. I was curious if anyone here has it and/or used it?
The other reason I'm sharing my experience, I was curious about whether I would get a warning before the red, stop engine light came on or did it just KABOOM come on and you are dead in the street. It pretty much can KABOOM come on; however, there are a couple of warning signs. I had no idea I was just a step away from the red light. So as it was explained to me. Check engine light goes off. 1st warning. Check engine light with check in it. 2nd warning. Next comes the red light. I'm not sure how many more miles you can go before you get it, but you've been warned twice so find safety.
My last outstanding question I have and I will be calling Spartan tomorrow. Is this a temporary fix? Or did the sensors detect something abnormal and the forced regen take care of it? Or do sensors need be replaced.
Oh and just another bit of information. My DEF gauge read that I had a full tank of DEF while this was happening. When I turned off the ignition and restarted the engine at the campground, it went to 1 green bar. That was confusing as I would think if you had one bar, it would be red. I did a visual check and my DEF tank was pretty full. It took on about 3 gallons. I'm not sure what was going on there. I believe it should have read 3 bars instead of 4. Will be keeping a watch on that for sure.
Any and all feedback is welcome. I learn so much through these dialogues.
