Tip Improving the Home Theater in my Newmar Motorhome
Have you explored YouTubeTV?
Whole family and all my friends LOVE IT!!
No. Slingbox was a great way to get "my" local channels such as local football, etc. I wish DISH with the local channels option allowed you to choose a zip code vs. the area you're in and then it would solve that problem.
Yesterday my Slimline Pioneer become unusable. It worked very well for about 3 years. Now it is stuck on “ pairing Bluetooth “
Nothing I tried it worked.
thinking about getting Marantz, but is a bit too tall? Or get the same model Pioneer. ?
Try pulling power for a few minutes?
Best to check specs on the vendor website to ensure it will fit. I would also check Yamaha for slimlines, I really like their receivers but at the time they didn't have an updated slimline yet.
I did leave it with the plug off for hours. No change. The display is black too. Will check the Yamaha, but there is nothing as slim as the Pioneer VSX-S520.
Not sure which model you have, but…if you can access it with the Yamaha app, you may be able to flash it back to the Factory Defaults. If you don’t have that access, see if there’s a shortcut to do a Factory Reset.
I have 2 Marantz AVRs, the latest being the NR1510. They’re nice, but not invincible to being fried. Ask me how I know.
Steve
I have Pioneer SVX-S520. It was a refurbished unit.
I just ordered a new one to be delivered to Polson. It’s only money ?
If you have a Newmar pre-2018 such as my 2017 Newmar Ventana Class A motorhome you may be lucky to have a real home theater setup. Newmar went to soundbars in 2018 probably because their setup was just not right in the prior model years and was all wired as analog vs. using HDMI connections through the AV receiver. Home theater is complicated and one I struggle with time after time to get right and probably never do get it right. I really enjoy my home theater at my S&B and with Newmar's 5.1 home theater configuration in my 2017 VTDP then why not make it great too.
I've been through several iterations of some of the components mainly the sub-woofer replacing the JBL wall mount (in the televator) to a Pioneer compact sub with amp (can't remember which size I used) and that was AMAYYYYZING but with my office desk setup that sub had to go so I switched to something that could all be contained inside the televator area. Details on that below.
The first thing I did was lose the Sony receiver Newmar provided. It actually is NOT a bad receiver but I needed something with more HDMI ports and more control via the menus for my always complicated home theater config. I am a Yamaha receiver fan (previously Onkyo Integra) as they have great IoT (Internet of Things) setup and really have come along with their receivers as I used them long ago then switched to Onkyo. But they didn't have anything recent or on par in the slim line (half height) receivers at the time (2017) so I went with Marantz. I have not researched what is available today but I can tell you I've been thrilled with the Marantz in every aspect from home theater to menu control, HDMI pass thru for the external TV, etc. The Marantz I bought which was the latest back then was the NR1608. The latest today is now the NR1710 which I'd probably get today as I prefer the newest but I don't see too much different warranting $300 more over what I got back then.
The next item to change are the small square speakers Newmar users to something real that can sound great and be ceiling mounted. I went with Polk ceiling mounted speakers (4) and a center channel speaker. I went with Polk RC80i for the four speakers and then at Polk 255C-RT for the center channel. If I did it over again I would go with a 6 or 4 inch speaker instead of the 8 inch RC80i but it sounds great.
The next element of the home theater is the sub-woofer. Like I mentioned above the Pioneer 8 inch I used which fit perfectly in the floor "notch" under the jack knife sofa and sounded amazing! But I had to remove it when I replaced the Jack Knife sofa with an office desk. The JBL compact sub-woofer Newmar wall mounted in the televator bay I think just didn't work probably as it either wasn't configured right or wired right. I learned during my replacement how these sub-woofers turn on/off either via a sense wire from the dash radio or a 9-12V power signal. I was able to wire in to the televator controller 12V supply so my sub is essentially always on now as I could not get it to work properly otherwise. I went with the sub-woofer below which has a self contained amp whereas the Pioneer used a separate 1100W amp which was amazing too. The pioneer was a better setup but I don't have the space for it and am just sticking with this for now and calling it done. I went with a highly reviewed Rockville RW10CA 10" 800 Watt Slim Low Profile Active Powered Car Subwoofer Sub.
Newmar included two monster HDMI splitters as they did not route everything through the central AV source - the AV receiver. Maybe there is merit to their setup for their intended use but in my case and theory all home theater components (DVD, Apple TV, SAT, etc.) should connect into the receiver, then the receiver HDMI OUT goes to the TV's. I've been through several variations of HDMI splitters but ended up now using this 4-way 4K splitter. Amazon.com
Finally, I really like the Logitech Harmony universal remotes that I use at home (S&B) but also have a smartphone app to control the home theater as well.
I'm late to the game with some things and Apple TV is one of them. I never had an idea of what it was, how it works, what does it do for me? Well, I love it and highly recommend it. I have one both in the front zone and bedroom of my coach. The Apple TV allows you to watch any of your streaming services that support Apple TV (Netflix and YouTube are what I use most) but there are apps for Apple TV just like smartphones. You can also send photos or videos from an Apple device such as iPhone or iPad to your TV connected via Apple TV. I actually have a slingbox at my S&B so I can watch anything from home (Verizon FIOS) in my coach assuming I have a half decent Internet connection. I then use the the slingbox app on my iPad to "AirPlay" to my Apple TV and then the audio/visual from home is on my home theater in my coach! I really don't even need DISH in my coach as I can watch cable TV from home as well.
Amazon.com
Amazon.com
In summary, just because it's a motorhome doesn't mean your movie watching etc. can't be great too. I'd love to hear of anyone that improved their soundbar setup with a surround setup, etc. for the newer coach configurations. I'm extremely pleased and enjoy my RV lifestyle the same as if being at home when it's time to disconnect the brain and watch a movie, etc.
WARNING: Any time you are cutting the ceiling panels you must carefully inspect for wire runs and cross braces! Use a dental mirror and inspect carefully prior to any cuts!
Amazon.com
Amazon.com
Neal,
New to us 2017 Dutch Star. This is going to be hopefully not the stupidest question you have received, but does the entertainment system (Sony AV stock) work like a "real" home theatre system? The reason I ask is it seems when I turn the AVR to sat or TV etc., it doesnt matter, it does not affect the sound or anything in the RV. Are the ceiling mounted speakers in the RV working off of that AVR and supposed to play the audio for sat/bluray/tv? Thanks in advance and sorry if the question was silly:)
Mark
No stupid questions - yes the Sony AV receiver is a decent receiver, the problem you need to look into his the path of your audio. Typically a source needs to feed into the receiver then the receiver sends the audio to the 5.1 speaker setup. My guess is your TV is sending audio out the aux jack to the stereo so you're not really getting a home theater experience. You need to take a careful look at the path of your audio from source to receiver to speakers and check all that out carefully.
Thanks so much Neal. I know it’s basic 101 AV stuff, but when I saw your thread, i figured I would ask:). So, if I were to purchase an updated AVR with hdmi inputs for sat/blu-ray/etc, then all the sources would go through the AVR via HDMI cables, an output HDMI cable would connect into an HDMI splitter, and then utilizing a 1x3 or 1x4 splitter, it would send to source specific audio/visual to each of the front three tv’s, which would then utilize the ceiling speakers in a true home theatre mode? How would cable and antenna work with that (Winegard)….not sure if that goes through the splitter/AVR at all. Thanks Neal:)
Obviously what goes in to the AV receiver will go out through speaker wires which go to your various speakers. You'll just have to think through your design and how data flows whether visual (HDMI) or audio via speakers. It's not always simple and takes time and planning, and of course many do-overs as I do.
Mark, you might have a switch near the dashboard to change which speakers are playing when travel vs. stopped. I can't remember specifically as I removed it's function.
Also, Logitech killed the Harmony brand of remote controls. The good news is the Allonis SmartRemote can reuse the Harmony Hub for all devices and Activities that are setup (plus a whole lot more).
You can map out the wires from your AVR to speakers by putting a 9volt battery across the speaker leads. Listen for the speaker to "pop" and label the wire. Remove the wires from the AVR first.
Yesterday I replaced the Sony Surround Sound AV receiver with a new Onkyo system with Bluetooth. When I disconnected the wiring on the back of the Sony I noticed a RCA cable plugged into the Subwoofer jack. It's impossible to trace the cable because it disappears behind the cabinet so I have to wonder what it's connected to? There is absolutely no bass in the sound system. Is there a subwoofer hidden somewhere in the coach? Why is there an RCA cable plugged into the amp?
To test the system I took a powered sub woofer from my Media Room and plugged it into the new Onkyo. BOOM!! What a difference. Its too big for the coach but it sure does sound nice.
My subwoofer in my Ventana is under the kitche sink deep in the back
