Breathing new live into my 2000 Dutch Star
I very much appreciate what you have done with your coach. Just finished reading the whole thread.
Thank you, going much slower than I would like. I guess working 50+ hours a week and being 68 slows a person down a little. Plus it is either raining or 100 degrees lately.
So upgraded my Headlights this weekend.
I bought new ones but can't figure how to get the old out :cry:
What do you have?
Older London Aire, but same light as mine. Watch this video, should help. The main headlamp attaches straight to the body..No "header panel to remove". Those clips are a little tricky and beware, they will fly off if your not careful. Also Newar added a extra screw on mine at the top inner corner. Had to remove a plug to get a screw driver in there. Longer screw driver than normal.
As far as getting the bezel out , mine had 2 10mm nuts on the back side of the turn signal lamp, the upper inner added screw, and one screw to the outer side marker light.
If you got new bezels, the top has to be cut down to fit.
Video? Is everything done from the front/outside? From the back I can't see how to get to anything.
Sorry about that.
Access from backside of headlight.
The joys of living in the country.
Open the wet bay door and greeted by this.
Pretty sure I am going to transform my cabinets from Honey Oak to Red Mahogany starting this weekend
Hey, I like that! You don't think it will make the interior too dark do you?
I like dark, but also plan on upgrading and adding more led lights
If I was able financially, here is what it would look like inside.
Very nice! You do beautiful work. My only suggestion is that unless you really use the hand-shower, you might consider replacing it with a more functional valve. Here’s what we did.
The short hose is connected to the black-tank rinse fitting, using a pair of quick-disconnects.
TJ, I need to do this and I found the website for the supplies. Does the faucet end on our rigs take a regular water hose thread?
