Disappointed at this point.
Not exactly Go Power is a fully integrated system that have “AN EXCLUSIVE INTERNAL TRANSFER SYSTEM” and offers RV industry everything needed to outfit most RVs. Everything would function properly with Go power inverter with switch in instead of WFCO inverter. I don’t think it’s the end user responsibility to fix issue. You are correct about the WF-5110R they come with 20’ cable and remote. Forest River elected to leave them out. After telling me its behind sliding door Or maybe it’s by the bed. No neither place. Must of sold them to someone else.
Not at all an unusual situation where two different systems are chosen for one installation. As I research, either the Go Power system should be used for coach power integration, or WFCO system should be used. Just a poor choice on the manufacturer's part. Most likely cost-driven.
While Go Power offers inverters and converters, I don't see where Go Power offers a power distribution system much like the WFCO system. WFCO does offer both the converter power distribution system AND an inverter system with automatic bypass when AC power is available. Seems to me that the Go Power system needs..........to go!
Sounds like if Forest river did not do there due diligence when they started offering the solar with inverter option. if there would have been a go power inverter with switch to accompany the go power solar controller they chose. The system would function properly and the other WFCO devices you mention are irrelevant.Check with any electrical or electronic engineer. All in the name of profit ignoring Forest River responsibility. Doesn’t seem like CUSTOMER SATISFACTION to me. Happy campers want to share thoughts. Future Forest River buyers?
The Go Power solar system is basically a stand-a-lone system. I view no reason to have it interface with the inverter. Also if the correct model inverter is used, there is supplied a cable and remote control switch. "The WF-5110R also has an exclusive internal transfer system which automatically allows the AC input to bypass the inverter when the inverter is connected to an AC power source." Not sure why one has to go outside to turn the inverter on or off. Seems it is automatic.
Perhaps to have the button on controller panel and in APP actually function as illustrated in the owners manual of the product. Just MayBe.
Based on my quick search, preference would be to use “ They make those systems. I did not find that Go Power does not make all of the systems required.
I did check with an electronic engineer. I looked in the mirror.
Bob
BSEE, MSEE, Ph.D. -Electro Physis
Based on my quick search, preference would be to use the WFCO system for power control, solar control, inverter control. They make those systems. I did not find that Go Power does not make all of the systems required.
Bob
BSEE, MSEE, Ph.D. -Electro Physics
Thank you Bob. You are partially right. If Forest river had used “the WFCO system for power control, solar control, inverter control.” All would be fine and dandy. But as stated Forest river mismatched components WFCO inverter with Go Power solar controller. They did not install the WFCO power control. Yea they ripped me off for that too. I forgot to mention that. Thanks for bringing it up. Also i do believe the Go Power GO POWER, GP-SW1500-TS, PURE SINE WAVE INVERTER & TRANSFER SWITCH would have cured all the electrical problems. With 100% compatibility. Run this by your engineer.
Bob did you have a chance to review the product mentioned in previous post. If not would you please get back to us. Many of us who have reviewed this product do believe it would provide 100% of the cure. Thanks again. OTHERS feel FREE to CHIME IN. Thanks for all FEEDBACK.
I don't find that Go Power makes a power distribution panel. The distribution panel has circuit breakers for the AC equipment, outlets, converter, and such. And also the DC distribution with fuses for, lights, pumps, refrigerator, and such.
I find that WFCO makes all of the items necessary. Go Power does not.
It does seem that the Go Power system could interface with a WFCO panel but will take some custom wiring to accomplish such. [Understand I am not giving advice regarding this issue. A systems engineer will be needed for this part of the issue. ]
Bob
Hey Bob. I found this in my notes.Regarding my Mismatched Electrical System with components that don’t interface correctly.I do believe all of listed coaches should be equipped the same + or minus options offered. Yes? Note all includes package E including a Bluetooth system control panel. One would think all of the buttons would work on a new coach. My buttons and APP slides don’t work. What would you do?
Hey Bob. I found this in my notes.Regarding my Mismatched Electrical System with components that don’t interface correctly.I do believe all of listed coaches should be equipped the same + or minus options offered. Yes? Note all includes package E including a Bluetooth system control panel. One would think all of the buttons would work on a new coach. My buttons and APP slides don’t work. What would you do?View attachment 9562
I see no option to resolve your issues other than to take it up first with the selling dealer. Perhaps try to get them to work with your local dealer to address and correct the issues.
Thanks for all of your help. That is exactly what I am doing. One last Question seeing all the facts do yo think Forest River Responsibility have been fulfilled? And There responses to achieve “CUSTOMER SATISFACTION “ are anything appropriate? Thank you again for all the feedback. All others are welcome to comment.
I would document the issues in pictures and written descriptions. Do so without judgment or opinions. Send copies to Forrest River Customer service, the selling dealer, and your local dealer who will likely be the one to service your unit. See what responses and offers and suggestions come forward in 2 to 4 weeks. Then decide.
Otherwise, I suggest you arrange locally to resolve the issues and begin to enjoy your new travel trailer. Just suck it up, pull up your big boy pants and move on away from the issues. Consider the money saved and money spent as "education expense". You most likely could have purchased from a local dealer, perhaps paid a bit more money, but have the issues resolved locally. Less aggravation that way. Surely the piece of mind is worth some monetary value.
