AT&T prepaid 55/mo 100 GB
Now that I have a 5G router I'm going to give this another try.
In store 1:40 PM
Agent 1:53 PM. Knew exactly what I wanted. Sim only data plan, no hot spot device.
Out store 2:03 PM
In store 1:40 PM
Out store 2:03 PM
Bought the SIM on line. Got it in two days. Good plan.
Awesome!
We are using this plan with our Pepwave.
Works well and happy with the plan as part of our internet setup.
I was looking for that option but didn't see it.
Get an AT&T prepaid SIM from your local Walmart, Walgreens etc or from Amazon and activate it here. I think the SIM just needs to start with 89014.
I haven't done it myself but I've seen several reports of people doing that successfully. I did mine in a store because the form didn't accept my IMEI about six months ago but it does now. I've been as far as the next page which gives you a choice of plans, one of which is the $55 hotspot / router plan.
In store 1:40 PM
Out store 2:03 PM
Can I put this in my Wi-Fi Ranger?
I had a WiFi ranger a while back and I thought they only connect to WiFi. I could be wrong on this. Now if have a hotspot you could potentially put the sim into the hotspot (check first for compatibility) and connect the hotspot to the WiFi ranger and then stream away. @docj can elaborate better than I can as I haven’t used WiFi ranger in a long time.
Have the same sim. Works great for me. Be aware you have to configure it to connect.
Thread 'AT&T'
AT&T
Last time I had this it configured automatically. I'm not a fan of setting any of the network related items in the cellular/details area, I think people can end up putting something wrong in there. I would highly recommend clearing out those values and rebooting and see what happens as the network and device should handle that automatically from what I've seen. I personally will not be setting anything UNLESS my Sim doesn't connect which was not a problem last time I did this nor with any sim I've ever used in a Pepwave. (AT&T, Verizon, Sprint, and T-Mobile)
@WiFiRanger can probably answer this for the devices that have SIM's. My guess is they are partnered to have their own plans, I'm not sure any SIM works in the SIM supported WiFi rangers.
Go to that form and enter the IMEI and see if it gets to the next page. It does some sort of IMEI check on the first page. If you need a SIM ICCID just to make the first page happy, try this 89014104272133835673.
That was the issue it would not connect on its own and the default apn was “tmobile”. I searched the internet and by changing the apn it connected. I am curious to see what happens when you boot up the router with default settings.
edit: I don’t have the 5g router so that may be different.
Actually, any AT&T or T-Mobile "data only" (hotspot) SIM should work in Rangers with cellular modems. Yes, we also offer AT&T FreedomGo plans from our parent company Winegard, but there is no requirement to use them.
All WiFiRangers can provide WiFi connectivity. Some Rangers are equipped with cellular modems. On some Rangers that lack modems, they can be easily added.
I put the AT&T 5G Prepaid SIM into my 5G Pepwave. As @sheridany experienced the APN wanted to use fast.t-mobile.net or whatever it was which prevented it from connecting. I changed the APN from AUTO to CUSTOM and left it blank. It connected now and works fine. I then tried using other APN's I found from "phone" "nxtgenphone" "broadband" all of which worked and made no difference. I decided to leave it set to "broadband", I checked my CAT 18 pepwave to see what it's using for the AT&T Mobley plan and it is auto set to "broadband" as well. I caution setting a PHONE value as we don't want these plans thinking they're being used in a phone. Here is a support article from AT&T I found hence why I'm using "broadband".
It was nice to see my Verizon prepaid unlimited plan connected as 5G when I arrived at my coach with 170 MB download speeds. I wasn't sure if the Verizon plan included 5G, glad to see it does.
