- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Now that I have a 5G router I'm going to give this another try.
In store 1:40 PM
Agent 1:53 PM. Knew exactly what I wanted. Sim only data plan, no hot spot device.
Out store 2:03 PM
Bought the SIM on line. Got it in two days. Good plan.
I was looking for that option but didn't see it.
In store 1:40 PM
Out store 2:03 PM
Have the same sim. Works great for me. Be aware you have to configure it to connect.
Thread 'AT&T'
AT&T
Can I put this in my Wi-Fi Ranger?
Go to that form and enter the IMEI and see if it gets to the next page. It does some sort of IMEI check on the first page. If you need a SIM ICCID just to make the first page happy, try this 89014104272133835673.Can I put this in my Wi-Fi Ranger?
That was the issue it would not connect on its own and the default apn was “tmobile”. I searched the internet and by changing the apn it connected. I am curious to see what happens when you boot up the router with default settings.Last time I had this it configured automatically. I'm not a fan of setting any of the network related items in the cellular/details area, I think people can end up putting something wrong in there. I would highly recommend clearing out those values and rebooting and see what happens as the network and device should handle that automatically from what I've seen. I personally will not be setting anything UNLESS my Sim doesn't connect which was not a problem last time I did this nor with any sim I've ever used in a Pepwave. (AT&T, Verizon, Sprint, and T-Mobile)
@WiFiRanger can probably answer this for the devices that have SIM's. My guess is they are partnered to have their own plans, I'm not sure any SIM works in the SIM supported WiFi rangers.
I had a WiFi ranger a while back and I thought they only connect to WiFi. I could be wrong on this. Now if have a hotspot you could potentially put the sim into the hotspot (check first for compatibility) and connect the hotspot to the WiFi ranger and then stream away. @docj can elaborate better than I can as I haven’t used WiFi ranger in a long time.
