Here is a thread from JL Wrangler that might be helpful
@jdshep1 @Roadmaster Have you had a chance to test the EC on lifted JL’s with 35x12.5 or 37x12.5 tires yet? I know that the version for larger tires will need more pressure, what pressure do you think will be needed? Any thoughts on an adjustable version like falcons stabilizer (soft,medium,firm)? I’m very interested in this and can’t wait to hear reviews from forum members.
Hucke
The most modified is my son's 98 TJ 4" long arm lift but only 33's and a V-8. That has been a test mule for a lot of offroad and highways. He does 80 in that thing and drives with no hands. Before we started it was hard to keep in a lane, the wind would also blow him all over the road now it is rock solid and he has a 75 lb unit and he says it is just right. My grand son has a Comachee with a lift and 35's. He says it drives real good actually better than my 2018 JL Rubicon when it was stock. We also had a 2015 JKU Rubicon that was stock. We have done a lot of RVs and HD trucks. A friend who is a fire chief had a new Ambulance Rescue truck on a Ford 4500 4WD. It had a short wheelbase and had a lot of weight behind the rear axle. It was very hard to drive over 50 mph uncontrollable. We put a prototype 220 lb unit on it and it turned into a big SUV. I test drove after and it was as good as any truck/RV I have ever driven. I have a new 2021 RV a Dynamax Isatta 5 28ss explorer 4WD on a Ram 5500 chassis at 20000 lbs. It was not terrible but not near as good as I wanted. The center was soft and hard to keep now with a 220 lb unit it drives like a Suv. You would not feel the change any pressure
I would think you would be very happy with any pressure 80 to 110 lbs. We put 90 lbs on a 2015 JKU Rubicon, I drove it 250 miles and thought it was great, the owner, my son's wife thought it too heavy feeling so we changed to solid rod ends and told her we lower the pressure. She liked what she thought was lower pressure but did not like the very fast sports car-like feeling. We then changed it to 75 lbs with poly bushings and this made her very happy. We did not tell her it was lower pressure, she just thought we changed the ends. Our RV unit has an on-the-fly trim feature. That makes install final centering a 2 second button push and lets an RVer trim the center to have the EC push against side winds etc. We did not think Jeepers would want that attribute. However, I have an idea I thought you (heavy mods, big tires, big lifts) might find interesting. I am an inventor so I would be interested in getting some users to test new ideas. This one would allow you to have full EC ability when you want, a trim feature(allows center change), and the ability to lockout part first 1"-2" of tie rod movement or all tie rod movement, it would just be as it is with no stabilizer if 100% locked out. We have a patented lock that will hold 600 lbs. We would give you a toggle-like lever to flip to shut off the centering part. This ability is not a product yet.
Fox and Falcon have their adjustment because you can really feel the changes and they need them. I suspect you want it adjustable because at 3 it is very stiff. This is different. We can give you the control you need with a very good solid center and a wheel you can turn with one finger. Watch the drive video of the 2015 JKU driven with one finger, which was a 90 lb spring. We need some users to report how they like the 75 lb and then give them 100 lbs to see what they think. I do not think even at 120 lbs on a big lift, big tire wrangler will be able to be driven with one finger. If we do not tell people there is an "X" pressure push back few would notice anything. The second day you drive your rig after an EC install I think you will not notice the pressure, it will not be anything you notice as heavy. This is not even close to the resistance a Falcon or Fox creates. My 2021 Bronco Outerbanks 2.7 has a much stiffer wheel than any level of assistance we have done on EC. My wife's 2020 Lincoln Aviator has very heavy steering too. Must be a Ford thing. I do not think you will want the Falcon adjustment, this is just a solid center and a solid hold at center yet still easy to turn. We have many videos, if you search there are several on Wrangler JL. More pressure will help people who do Toad backing as it fights additional weight the front tires out on the ground making them want to turn.
I need RM to get to their pressure change in house (near complete) so we can try a few things.
Maybe this new steering stabilizer will minimize the need for constant corrections, thus a JL with a small dead spot will be less noticeable since you won't have to correct as often.
You need to try a base unit EC and see how you like it.
Yes, I already ordered it on Dec 30. Waiting for it to arrive.
