Question Ice in black tank
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
A camper I was talking to said that when he is going to be on the road for a full day he empties a bag of ice into the toilet / black tank to clean it.
Is this a good “ hack” or is it just an urban legend?
I've heard this before, I think the theory is the ice moving around just as if it were rocks to help loosen the build up areas. The question is how long does it take before the ice melts vs. having any significant motion to make it do what one thinks it would do? What I personally do at times is put cascade in both tanks and add about 10 gals of water. Let that slosh around and then drain rinse drain again the tanks. I will use Dawn at times, and I've heard of some using pinesol.
put enough ice in and i can see that working to break up debri stuck!! I use ice in coffee carafe when I clean it.
It would take a whole lot of bags of ice to do much good. More legend than truth here IMHO. Would really be tough to do with a macerator toilet😂
There is a YouTube video of a guy doing an experiment about that. His conclusion was don’t waste your time or ice.
Ice is cheap, No harm done, very little time spent. I was told this method by an old long gone friend. I am going to get to try it out as the camper we purchased has the beginning of a poo pyramid and the sensors don't work. Will report success or failure.
2X.... I wouldn't waste time trying it even if I could (we have macerating toilets). Save the ice for cocktails! Between moves use water and dishwashing soap or Dawn instead.
As stated before, macerator toilet would just make a poop slushy. There is a mineral called Struvite that builds up in both black and gray tanks. Watched a Youtube video of a guy that pressure washes the insides to clean the sensors. Sooooooooo, I had an idea using a rhino blaster adaptor. Drilled a half inch hole and fed a 3/8 fuel line with a garden hose adaptor on the outside and a multi directional spray tip (I made mine) and fed it up in there letting it flop around and rinse for about 10 min. and tanks read correctly now.
Lol!! If your going to try this and use the ice from the home ice maker, make sure the wife isn't home!! And yes, I don't think my maceration toilet would enjoy that ice to much!!
In case you are wondering (this may not be news....) that pyramid is from leaving the black tank valve open while hooked up to a sewer connection. This allows the liquids to outrun the solids, leaving the solids to build up into said pyramid. Much better to leave the valve closed and dump periodically. Same with grey but for a different reason: this gives you a lot of realtively clean and soapy water to rinse the dump hose after you dump the black.
As for ice, Im more in the strong detergent camp (but I also have a macerator toilet). Ill often drop a laundry soap pod in with my tank treatment pod and several gallons of water when driving to do the extra clean-up duty. Cascade (or any dishwasher soap) sounds good too because its a stronger detergent.
Yes, I am aware but bought the camper used late last year and only used it once. The pyramid is already there. I would have taken care of it on the way back from Eastern Maine, as the roads down until Maryland are atrocious any time of year. It certainly would have been shaken not stirred. Round ice cubes would have worked in Massachusetts. I was not aware or up to speed when we left, or it would have got something to swirl around for 2 days.
Well now we have been using ice. We usually put in two bags on our way home from a camping trip. After my wife and I watched the video we decided to change to the soaking process that Neal suggested. Learn some thing new every day.
Why not ice and some detergent? Has the ice been working? I find that the video's can be deceptive. Like his video's, but still will try both methods with a poo pyramid that is old and entrenched. Patience will be a key factor.
