Russellvh
- Nov 18, 2021
- Home based out of the Colony, Texas
- Forest River
- Wildcat Fifth-wheel
- 2019 Ford F-250.
- Yes
2X.... I wouldn't waste time trying it even if I could (we have macerating toilets). Save the ice for cocktails! Between moves use water and dishwashing soap or Dawn instead.There is a YouTube video of a guy doing an experiment about that. His conclusion was don’t waste your time or ice.
I was going to post that same video. Well worth the watch and sure does debunk the ice myth.
In case you are wondering (this may not be news....) that pyramid is from leaving the black tank valve open while hooked up to a sewer connection. This allows the liquids to outrun the solids, leaving the solids to build up into said pyramid. Much better to leave the valve closed and dump periodically. Same with grey but for a different reason: this gives you a lot of realtively clean and soapy water to rinse the dump hose after you dump the black.Ice is cheap, No harm done, very little time spent. I was told this method by an old long gone friend. I am going to get to try it out as the camper we purchased has the beginning of a poo pyramid and the sensors don't work. Will report success or failure.
