Side view cameras seem no better, and maybe worse than, side mirrors?
bpaikman
Lake Jackson, Texas
Ventana LE 3436
35 feet
Cummins 340 hp
We thought side view cameras would be great, But now that we have them I find them annoying. I still use the mirrors. When I give a turn signal and it immediately cuts to that sideview on my camera, I feel that I've lost, not gained visible area.
For example, when merging right after passing someone, I watch the rearview camera and the side mirrors so I can tell when the tow vehicle is well clear of the vehicle I'm passing. It's disorienting to suddenly lose the rear view as the camera screen cuts to right side view when I switch on the right turn signal. The side view is already (better) covered by the mirrors. I actually would like to disable the side view cameras. Does anyone else have this problem or am I just not accustomed to them? Or maybe you have 2 screens and keep both views? (I have only one screen).
Yes, I will occasionally glance at the side view camera, as a double check, but I have been driving other vehicles with no re3ar view mirror for over a decade and a half. So I am very used to driving by the mirrors only. The side view camera may help when some idiot decides to creep by on my right, before I get a safe distance to pull back over.Many times I have been fortunate enough to just catch the roof of one of the nuts in my blind spot as I begin to pull over. Thank God I never hit one. I think this is why many truckers don't give much space anymore after passing.
I am not sure if there is a setting to change this. Check the manual, if you haven't already.
I also find the location of the video monitor to be poor and even counterproductive to safe driving. I rarely use the turn signal cams as a result.
Now, if they could figure out a way to to put the cams in a heads-up display, that might be a different story.
As AbdRahim stated, I use the side view camera only to see what is in the blind spot that my side mirror won’t catch. The rear of the coach and trailer is way too far away for the wide angle of the camera to be of any real help to know when I have cleared the vehicle on the right, as “objects in camera may be closer than they appear”.
In addition to the side camera I also check the mirror above the passenger door (that looks straight down into the blind spot under the passenger door).
Agree the side view cams are more or less worthless (angle too wide) and counterproductive when changing lanes and I could still use the rear view cam for toad clearance but I have the turn signal on, so the side view cam is on, showing essentially nothing useful, and not showing what I really would like to see. Because of this I generally wait to use my turn signal until after I can see my toad is clear in the rear view cam.
I would like to get one of these.
It is convienient to have it when the blind spots are large enough to contain an elephant.
Both my side view cameras are blurry for some reason. The rear is clear as a bell. I've tried cleaning the lenses but that does nothing to help the problem. Any idea what the problem is?
I’d suggest talking to these folks. I have never bought from them but other Prevost owners have had good luck with them.
That guy deserves as much business as he can stand. He helped me untangle the Newmar 360 cam mess, and he had not a thin dime to make by doing so. Great guy who knows his stuff!
My rear camera is blurry but my side cameras are clear.
Wife can see the chevy behind us in the rear camera and that's all I care about, making sure it's still back there.
I just use the mirrors for most everything.
I didn’t like the side view cameras coming on when signaling all the time, so I spliced into the system wiring for the side cameras and installed a DPST toggle switch so I can control when I want them live or not. In heavy traffic I prefer to have the rear cam on all the time for knowing when I’m clear to change lanes in tight spots.
My camera's display is down quite a ways on the dash. It's just not automatic to look down there to check the side camera (that seems to take FOREVER to turn on, then off again). I end up using the mirrors exclusively.
Ditto. I mostly use the mirror, but try and remember to glance at the camera for a double check, especially in heavier traffic or if I haven't been keeping track of traffic around.
