Diesel pusher making occasional "ch" sound while traveling
bpaikman
Lake Jackson, Texas
Ventana LE 3436
35 feet
Cummins 340 hp
I have two questions -I'm not sure where to put them. i'll make two separate posts.
First question: Since we're having some airbag issues I'm a little sensitive now to any sound. Is it normal to hear a "ch" sound, somewhat like the brakes make, while traveling down the road, about every 15 to 25 seconds? We had diesel pusher for several years before this one, and I can't remember if this is normal.
We're having some issues with our airbag or solenoid.... and the freightliner guy I talk to on the phone suggested that the bags might be over-inflating, so I was thinking about that "ch"sound.
Normal - it's the air tanks popoff valve.
That’s part of the air dryer system. There “can” be issues that will make that valve purge more often than it should. Water, bad regulator being a couple.
Some rigs, like our’s, will only give a hard pop-off when the tanks come up to pressure. After that, it’s rare I hear it.
Well, hmmmm posting next question soon
With our rig, I will occasionally hear the pop off release. Nowhere near as often as you are hearing it on your coach.
Agree with the above, every 15-25 seconds is not normal.
What do your air gauges read when the sound occurs? Does the psi increase or decrease after the “ch”? This my help isolate an issue.
We're not driving right now... been parked for two weeks, but the gauges stay steady while we're traveling.
I'm looking at three clues right now, Which might be all or none related:
1... that "ch" sound
2. the porpoising that occurs occasionally ( we're trying to determine if there's a series of actions that leads to that)
3. the fact the equalizer does not dump air before leveling
Gotcha, maybe the three issues are related?
I called Equalizer Leveling Systems and Freightliner today and they were not helpful.
I called Newmar and got a lady who offered to contact Freightliner with me on the line.
I wasn't excited about that suggestion because I had already called Freightliner and was told to look up the nearest service center.
We were finally connected to a man who seems to be extremely knowledgeable about the airbags. He offered reasonable explanations for the things we were experiencing, and tactfully suggested that our problem was operator error. He also mentioned, if we still needed service after trying his recommendations, which service centers might be easier to get into ...not quite so heavily trafficked by commercial trucks.
We are due to move on Sunday, and we will try his suggested procedures. If we are successful I'll post information about that.
normal
Operator error? How can that be when those systems should be basically automatic?
We were told by the Freightliner tech that the engine should be running and pressure normalized BEFORE raising the jacks, for proper inflation. We were raising the jacks before we even turned on the engine.
'We'll try this Sunday. He was pretty credible - outlining to us how all 3 of our concerns could be related to this.
That sounds a lot like the purge valve on your air dryer caused by the air governor used to do way back when I was driving big trucks. Do you have an air dryer in your system? You should with air brakes.
