- Nov 2, 2019
- Fulltiming
- London Aire 4551
- Yukon Denali
- Yes
So now that I've buried my viair and moved on to the doubler, I bought an air hose yesterday. I still need to get a tire inflator with a digital gauge. Can anyone recommend a good one? I've looked at the following.
Spartan sells the Astro 3018 (cheaper at Amazon), but when I watched someone using it and it appears that you cannot see the psi as you are inflating.
www.astrotools.com
Then I saw this one:
Milton S-576D Pro Digital Tire Inflator with Pressure Gauge, 15" Hose Classic Dual Head Chuck, Easy to Read 0.1 Display, Made In USA 255 PSI Amazon.com
Or maybe there is another one I need to consider? I'm open to suggestions. Thanks, as always.
Renee
3.5" Digital Tire Inflator with Hose | Astro Pneumatic Tools
New dual AAA battery powered design. 4X the battery life and simplified battery installation. New 21” Stainless braided hose for increased durability Maximum accuracy and 0.1psi resolution for use with TPMS (Tire Pressure Monitoring System) Displays KG, PSI or BAR measurement Large face backlit ...
Renee
