Jim
- Dec 18, 2019
- North Carolina
- Essex 4543
- Spartan
- Cummins / I6 Diesel Pusher 605HP
- 2016 Jeep Rubicon
Where did you find them chrome rings?I just installed the chrome vents this week. Always thought the black ones looked cheap and ugly.
Thanks. Still working on the steering wheel. Have to get someone at spartan to talk to. Newmar couldn't answer.
These are not a remove and replace item. The holes in the dash have to be enlarged ( very careful measuring to fit right) and I had to use part of the old vent with the new vent asm to adapt the size to fit the hose.
Here is what I have used on the dash.. So far.You have to list the items you use as a lot of us have the same or similar fittings. Thanks
If you want one of the "Forever Sharp" steering wheels, you need to talk to Forever Sharp for the correct adpater, not Spartan or Newmar.Thanks. Still working on the steering wheel. Have to get someone at spartan to talk to. Newmar couldn't answer.
Thats how I felt about my coach model #. Overall its a very nice coach but the model number was just black tape type numbers. Looked cheap. So I peeled them off and gave it a nice chrome “3427” more befitting the quality of the coach.I just installed the chrome vents this week. Always thought the black ones looked cheap and ugly.
Thanks will do.If you want one of the "Forever Sharp" steering wheels, you need to talk to Forever Sharp for the correct adpater, not Spartan or Newmar.
Pretty sure this is the one you need, but would check with Forever Sharp just to be sure.
Big Rig Conversion Plate 5 Hole Adapter to 5 & 6 Hole Steering Wheel
This conversion plate allows you to install Forever Sharp's 14" and 15" steering wheels (5 & 6 Hole Only) onto our Semi adapters. Simply sit the conversion plate between the adapter and steering wheel.fssteeringwheels.com
I will be ordering a wireless 4 camera system for mine as the voyager system died. Haven't decided which one yet. It is kind of at the bottom of my list got 2 good mirrors and use the wife as a ground guide if needed. I'll take a picture of my head unit that I have 10" screen and you can project y our phone to it.Here is what I have used on the dash.. So far.
I would opt for a 4k camera system over this one.
Be sure and order correct for your rig adapter for steering wheel![]()
18" Dark Wood Steering Wheel Chrome 3 Spoke For Big Rigs w Horn | eBay
Includes: Steering Wheel and Horn! SKU: 804CH-DW-TRC5-FS. Interchange horn button. STEERING WHEEL FEATURES Wood grip stained in 8 layers of urethane coating. 5 hole wheel bolt (Standard). Backside finger indentation for a comfortable grip.www.ebay.com
Not installed yet.
