- Feb 18, 2020
Hope this helps someone else. Noticed the residential fridge and the microwave (both run off the inverter) lost power briefly. Looked at the Magnum control panel and it was flickering as well as showing bulk charge at zero amps. My neighbor suggested I check my 18 month old AGM batteries. He said one bad battery would cause my issues. Made sense to me so I disconnected all eight batteries and used a volt meter to check for an obvious bad battery. All showed slightly over six volts. Loaded them up and took them to O'REILLY'S to have them load tested. I had one battery that was bad.
Reinstalled the batteries and everything is good. FWIW the bad battery was the last one in the series before it went to the chassis ground.
Now I know I need a battery load tester. That way I won't have to remove all the batteries to get them tested. I'll still have to disconnect them but won't be lifting and hauling all of them to the parts store to be checked.
The only thing that works all the time on a RV is the owner.
