New to RVing! The toilet!
The RV National Training Center that trains RV techs put out a video test on several of the popular products and the one I link to below is the winner. I have used packets and Happy Camper I can't tell if one is better than the other. What I do like about the product below is that liquid and easy to get into the black tank through my macerator toilets.
Yup, I graduated from there in Oct. Have used it successfully a couple times since. One was real bad, real bad.......no more room for anything......gads the things I get to see. But it released after a few days without my involvement....you get the idea....
They have more then one product for different scenario's.
I got a bottle of the Sensor Cleaner but have not had to use it yet. It was interesting when he said don't clean the toilet with bleach or anything that will kill microbes in the black tank.
I’ve been in the same spot for 10 days - a record for me, and since I’m hooked up to everything, I’ve kept the toilet on wet bowl. This has put me over 2/3 of a tank almost every day, so the tank has had a lot of flushing and consequently the sensors are reading correctly. No additives in the tank of any kind. Just a lot of water and near daily dumping.
I’ve been contemplating adding some dishwasher detergent since its non-sudsing and a fairly strong cleaner. I tried laundry detergent pods and it caused a big sudsy mess in the system, fouled the sensors, and required a lot of rinse and flush cycles to get it out.
The water police will be knocking on your door.....
We had the misfortune in building our current home just after the overzealous water police (i.e. those in the Federal govt) issued regulations on toilet flush water use for homes and before good sense prevailed and/or the manufacturers figured out how to make the low water use toilets actually work.
So, they didn't work. So, I had to adjust the tank float to fill the tank to the brim and even then frequently have to flush twice. ~25+ years later, we still use those toilets and they still use even more water than the pre-regulation toilets did.
Worked out well for the water police, didnit? ;)
Lesson: feel-good regulations have to result in products that actually work or they are self-defeating. Apparently, few in fed or state governments have actually learned that lesson, though.
PS: @TheLooks, this isn't directed at you. I just used your post as a launch pad, so to speak...
I was building houses as a contractor when the rules went into place. I managed to get an old toilet from the 60's for my own house until they worked out the problems. They would call it a success that they forced change which eventually led to something better saying it would have never happened if they didn't.
