DT04-4P-RT What is it and what does it do?
Jim
North Carolina
Essex 4543
2016 Jeep Rubicon
I was digging around in the fuse compartment (in the small basement storage area under the driver seat) and I found this guy with signs of having been very hot somewhere along the line. It appears to terminate a series of wires or to connect them together, but aside from that, I have no idea what the wires do or where they go.
2016 London Aire 4519
Anyone have any ideas?
I would try the directional signals or 4 way flashers and maybe high/low beam headlights to see if they work with that removed
DT04-4P-RT is a “molded in diode”. Don’t know what it goes to, but it shouldn’t over heat. Could be in the chassis lights system as @Chargerman suggested. Or….? Are you getting any DTCs?
Another Newmar owner (same year/model coach) had the same problem. Not yet 100% sure, but it appears this might be a recall for a wiring harness problem that is only current when the headlights are on. I'm checking with Newmar when the sun comes up.
Edit: 8:20am
Headlights are indeed compromised. Turn signals are operational, so are running lights, so at least I'm not dead in the water. Have an appointment with NIRVC in March, so I'll have this addressed at that time. Meanwhile I'll have to drive only during daylight hours.
Edit: 9:14 Newmar and Freightliner both say it is NOT a recall item.
I’d like to ask a dumb question…how is it that a significant Newmar dealer sell an RV without working running lights? What am I missing? That seems like a legal irresponsibility unless they were transparent about it in the delivery? There was a recall back in 2018 for headlight issues but I don’t recall it being about operational lights.
Naturally. Just a chassis electrical safety issue….
Wonder if this would get some attention:
They worked when I received the coach. That changed somewhere between Montgomery AL and Pensacola FL when I turned on the lights due to a massive rainstorm. While I was checking fuses for the heated seats I noticed an electrical smell in the bay under the drivers seat. This wasn't the condition of the diode when I left NC., or I would have noticed it.
So I don't know, it this part something that would self-destruct (similar to a fuse) in the case of on overheated wire? Maybe it did what it was supposed to do?
I'm waiting on a return call from the local Freightliner parts as to the availability. Worst comes to worst, I'll hang a couple of flashlights on the front. :-)
I'm waiting on a return call from the local Freightliner parts as to the availability. Worst comes to worst, I'll hang a couple of flashlights on the front. :)
Diodes will last a very long time unless subjected to too much current - then they blow. If you want to do a little research, contact TE Connectivity:
As luck would have it, there is a Freightliner parts/service/sales 1 mile away. Found out this is not a Freightliner part, but they ordered it for me from one of their providers. $127.17 with overnight shipping! Oh well, had to have it, so it-is-what-it-is, right?
My concern is not so much what it cost, but what caused it to overheat in the first place. Hopefully it won't happen again, but we'll see.
Did any water get into that bay of the basement? You said it was a huge rainstorm...
Got the new part, installed it, and the lights now work. But the diode is getting quite warm. That may be normal, I don't know. But for the time being, I'm leaving it out and will only drive during daylight hours. I have an appointment at NIRVC in Atlanta in March, so I'll let them figure it out.
@Jim , coincidentally, this vid dropped this morning. Go to about the 6:30 mark.
That's it! That's exactly it! I know of another fellow who has the same problem as well, so it's not just an isolated case.
Thank you, Neemer!
Yes thanks for the post, and video. I guess I need to check mine.
