Question Hello, new and confused
Not exactly truthful! Hitler added fluoride to dumb down the masses, and make them more controlled, his plan stated that fact. . It's claimed to be a carsonagen, and lethal to children.
My point is just because they put it in the water...
One more point! Although they in the past used chlorine to treat water, now FDA now recommends ClO2. That is not the same thing, and can be found at KVlabs on the web.
I suggest you take that up with the folks at Harvard.
Bob
Don't need to! This is the data sheet
Of all the poison in the water this is the worst, and it's a poison that is added. There are only three ways to nutrilizes fluoride, or remove it.
1. Bone char filter = nutrilizes it.
2.ozone bubble it= remove 95 percent.
3. RO filter = 95% removal.
Why should you care?
Causes osteoporosis.
Is A carsonagen.
If you are actively seeking truth, the pineal gland is calcified by fluoride.
But we went there because we were talking about chlorine, and would they add something to our water that could do us harm. The answer is, do you think they did the research? If you think they did,then like Hitler it was intentional!!!
You can sterilize with Chlorine Bleach. Be sure like stated above to rinse it well out after a day. I have used Chlorine Bleach before a trip. I triple rinse the tanks afterwards.
When adding Chlorine Bleach your my tanks, I add it to the same garden hose that I use hooking up to water at a campsite. This trick cleans the fill hose also. It rinses the Chlorine Bleach out to the tank(s) to get diluted to sterilize your fresh water system. Then rinse everything.
Shower and wash dishes with your tank water. Drink bottled water.
Just remember to not sterilize everything. Your body needs some "contaminants" to keep your immune system healthy. Covid lockdowns taught us that. I always knew.
This is usually what we do also.
