The portable has worked perfectly in the past unfortunately I only have one 4 prong plug that fits the generator so I had to switch between a 50amp 3prong for my welders and plasma cutter back to the 4prong 50a rv plug... and like I said in the first post the wires weren't in the correct spots. They are now and things aren't working the way they have in the past so I need to track down what may have fried or blown a fuse
The generator and the extension cord are a great place to start and I might find the problem but if they check out okay I'd like to be prepared on what I should check next rather than having to post yeah they checked out okay then wait for replies after that
I will also get some propane and make sure the onboard is working the way that it should but I mostly concerned about the shore plug and what could have fried.
